Question about Whirlpool AD35USS Dehumidifier
Will not drain out of the hose i have to keep emptying the pan i thought it was suppose to drain out of the hose to keep running
    Brigadier General:
  • 4,736 Answers
If the hose is connected to the tap on the drain pan/bucket, did you knock out the center of the hose connection on the bucket? If you didn't that's the problem. If that's not where your hose connection is located, do not put the bucket back in. It triggers the unit to fill the bucket and not use the hose drain. Keep in mind the hose must remain lower than the connection on the dehumidifier to drain properly.
Posted on Mar 22, 2011
Is there a place to connect a hose so dehumidifier will drain into a basement drain?
You don't say what manufacturer or model unit you have, but many models have places at the bottom of the collection pan for a hose connection. Just remember that the basement drain must be lower than the top of the drain pan or the pan will not drain out of the hose.
Jul 07, 2015 | Dehumidifiers
Once you punch a hole in the receptacle, what type of screw cap would fit.
Most of the hose/drain connections i have seen on these have a std gardenhose fitting so you can use a std garden hose to direct the water over to drain, caps for garden hoses are easyly available from any garden supply store , but i do caution you on your thought process of hooking up a hose makes this a maintence free option, it does not as hose and filters still need constant cleaning , especally in high humidity seasons
Sep 09, 2014 | Whirlpool AD40DSL Dehumidifier
Dehumidifier leaks
One open, other closed.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Jan 16, 2014 | Kenmore Dehumidifiers
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
I just came home to my DeLonghi (DEN500P) leaking on my basement floor. The bucket will not fit flush because the clear drainage tube has detached. I use the manual emptying method. I have the manual,...
there should be a pump somewhere near the pan, the pickup for the pump must go into the drain pan somewhere if you can find the pump, the nipple the hose attches to is close by please rate
Aug 01, 2011 | DeLonghi DE500P Dehumidifier
Permanent drain won't work... we attached hose but it keeps filling up and turning off indicating it its full. the hose is attached correctly but do we need to till the dehumidifier a tad backwards?
The pan itself should be sloped towards the back....ensure that the drain pan is installed correctly and that the hose or outlet fitting is not blocked . It will not do any harm to give it a little extra tilt especially if the floor isn't level
Oct 27, 2009 | Dehumidifiers
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
Connected Drain Hose - Is not draining, what gives?
Usually all you have to do is to remove any cap on the outlet fitting, attach the hose, & make sure it has a downhill run to the drain or well. Visual inspection should be enough to guarantee no obstructions exist.
Jun 24, 2007 | Haier HDN655E Dehumidifier
Whirlpool AD35USS Dehumidifier Logo
1,346 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
