Question about Dryers
Make = whirlpool, Model YLER7648DQ8 the gasket at the back of the tub has started to shred and fall apart, is it hard to replace?
  • 744 Answers
See this link:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=YLER7648DQ8
Then select your model number. You will need to disassemble the dryer to replace this part.
Posted on Mar 21, 2011
I have a Whirlpool dryer model leq9030pq. It is 7 years old. It still dries fine, but the gasket (or whatever it is) at the back of the drum is coming away and the dryer is making a lot of noise. Is...
may need drum rollers which if you are real handi and willing to take apart machine .Hard to explain how on this.Gasket in back would cut off whats falling away. It take some of the efficiency away from the drying. not hard to replace but messy. You get a gasket and this very stickey high temp glue with instructions.
Nov 07, 2013 | Dryers
Small item like sock get from the tub into the filter
its falling between you rubber gasket and the stainless tub happens all the time . but you may want to inspect the rubber gasket to see if it is out of place or torn.
Feb 20, 2013 | GE Washing Machines
My whirlpool duet front load washer has loose fins in the tub. how do i tighten them??
You're not gonna like this:
Pull the washer tub (see elsewhere on FixYa for step-by-steps), split the tub by removing the screws holding the two halves together, and remove the inner tub. Bend any tabs tighter that hold the fins on, and tighten any screws. While you have it apart, check for grease stains or other leakage on either side of the outer tub, and ensure the inner tub bearing is tight so that the inner tub shaft rotates smoothly and without oscillation. If there are stains or if the bearing is showing wear, replace that (back) half of the outer tub to replace the bearing (unless this is one of the few machines that allow you to replace only the bearing). You don't want to put all this back together, only to have to take it all apart again when the inner tub starts hammering on the inner tub because the bearing went south.
Jul 24, 2012 | Whirlpool WFW9550WW Duet Steam 4.4 cu. ft....
I have a whirlpool Duet washer model GHW9150PW0 that began to thump during the spin cycle. I removed the front and it appears the inner tub is off-center or out-of-round. Further, it has worn off the...
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
When the washer spins it makes a banging noise and the plastic around the tub shaves off
Thank you! We took our Duet 9150 apart and found that ALL THREE support arms were cracked. Same problem with shredded front tub also. My washer is a little over 7 years old. I called Whirlpool at the above number (you can't get "warranty service" but the parts service lady transferred me to the warranty dept). They were most helpful, and are shipping me both the metal tub AND the plastic which the metal destroyed, free of charge. Apparently your experience has shown them they have a problem with this...or I got a more helpful service agent!
Jun 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can bottom of bathtub collapse
The answer is yes.Most of your moble homes have poly or fiberglass tubs with litttle or no bracing under them and the floors are made out of a fiber type board. When they get wet they warp, crumble and fall apart, so if water has gotten under the tub there isn't much of a floor under it. But yes it can be repaired. She will have to remove the old tub and the wall board around it And probably have that portion of floor replaced.
Dec 02, 2009 | Home
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Dryers Logo
Top Dryers Experts
