Question about LG Televison & Video
TV has frozen will not respond to remote control (yellow button on right hand side of tv flashes when remote button are pushed) can not operate television manually as will not respond either
  • 72 Answers
You can try to leave in unplugged from power for 10 mins, then try again. But in all likelihood something as cold soldered on the inside you can either try to get warranty (if applicable) or get a new one.
Posted on Mar 21, 2011
Need instructions to use the Dish NETWORK remote for on-off and volume control.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 03, 2016 | DISH Network Televison & Video
How can I hook up my insignia lcd tv model ns-32lb451a11 to dish network with dish remote?
Is the remote capable of controlling other items check the handbook for the dish system for TV control set up if possible
Dec 24, 2015 | DISH Network Televison & Video
Samsung lcd tv can't find a source, buttons on remote control don't respond, nor buttons on the control panel on the right side of the TV device
consult the owner manual or call Samsung---this set likely has a lockout feature that locks both the remote and the keyboard out.
You might also want to research this by taking the model number and Google key words "remote lockout" etc.
Jun 01, 2012 | Samsung Televison & Video
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
The battery is brand new on my remote and the red light flashes when I push button but the tv doesn't respond.
Is it one of hose remote that needs to be programmed for your TV or original reamote?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Please post back.
Oct 29, 2010 | Sharp LC52D85U 52 in. LCD TV
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
I can not get the emmerson tv i have to go into video mode. I do not have the origional remote that came with the tv or the manual. The remote i have is programed with direc tv. how do i get the tv into...
In the upper left hand corner of the DirecTv remote there is a button labeled "TV INPUT" just push that button. Each time you push it it will change the inputs for the TV. If that is not the problem, the remote needs to be programmed with a code for your TV. If that is the case push the MENU button under the circle in the middle of the remote. Scroll down to PARENTAL, FAV'S, & SETUP, push the yellow SELECT button in the middle of the circle, scroll down to SYSTEM SETUP, then scroll down to REMOTE and push the yellow SELECT button again. From there you should be right as rain. On my TV and setup, I have a device hooked up through DVI, but the TV won't recognize it unless it is powered on. In otherwords when pressing the TV input on my DirecTv remote it doesn't show the DVI device (PS3) unless it is powered on. I hope this helps and good luck. Please vote and leave a message.
Oct 30, 2009 | Emerson CR202EM9 TV
Remote contol will not work
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
directv remotes are not guaranteed to work w/ all types of TV's. when programming remote to TV, make sure you are holding down MUTE and SELECT both at the same time for about 4-5 seconds. until it blinks twice at the top of the remote. also the slide switch must be under the "tv" mode on the right hand side. the website i provided is by directv, and has a list of their codes for the brand of tv that you have.
if you are trying to program a remote to a directv box, and none of the codes are working for the directv box, contact directv to have them send you a new remote.
Jan 22, 2009 | Directv D11 DTV Receiver
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Televison & Video Logo
126 people viewed this question
Computer Repairing
Computer Repairing
