Question about Trendnet Wireless Internet Surveillance Camera TVIP100WN
Hello, I've followed the steps to set up my tv-ip100(w)-n trendnet camera, but when I open the setup, the camera can't be found to run the wizard. any ideas? I've tried turning off windows firewall, tried pushing reset button for 15 seconds on the camera, tried unplugging wireless router and camera....just can't get anything to work. Thanks for any help! Brett
  • 2 more comments
  • chad788 Mar 23, 2011
    I need to make sure you have the camera connected to a computer via the Ethernet port. I also need to know what version of windows you are running. Let me know so I can explain how to resolve the issue.
    Thanks
    Chad
  • brettschoen Mar 23, 2011
    I've had camera connected to computer via ethernet, reset it, tried typing camera IP directly into internet browser....so far no luck with any of that.
    I'm running XP on the computer I want to use it on.
    turned off wireless adapter, no change. IE browser said "address not valid"
    I even "reset" the camera without any success.
    IP address: 192.168.10.31
    subnet mask: 255.255.255.0
    default gateway: absolutely nothing
    Problem Solver:
  • 14 Answers
I need you to plug it back in using the Ethernet connection.
You will need to change the ip address on your lan adapter.
When you plug the Ethernet cable into your computer there should be two little computers that popup on the lower right hand corner of your screen. You need to right click the computers then select (STATUS), (PROPERTIES), (INTERNET PROTOCOL TCP/IP), (SELECT THE BUBBLE THAT SAYS (USE THE FOLLOWING IP ADDRESS). THEN TYPE THE FOLLOWING:
IP ADDRESS= 192.168.10.31 THEN HIT THE TAB KEY
THE SUBNET MASK SHOULD AUTO FILL.
THEN CLICK (OK) AND (OK AGAIN).
OPEN AN INTERNET EXPLORER BROWSER
TYPE 192.168.1.30 IN THE ADDRESS BAR AT THE TOP.
USERNAME: admin
PASSWORD: admin
That's it your in if you need help with the setup let me know.
When you have completed the setup of the camera you will need to go back into the network adapter setting and select the (OBTAIN ADDRESS AUTOMATICALLY BUBBLE) in order to get back on your local network.
Thanks,
Chad
Posted on Mar 23, 2011
  • 1 more comment
    This is similar to what I had been trying, but with a different IP address than was recommended by the manufacturer. I was able to go into properties and change the IP, then I went to Internet Explorer and entered 192.168.1.30 into the address bar, but just like before, it didn't find the address, it just pulled up search results after a while.
    Do I need to change the IP of my wireless network or is there a conflicting address somewhere else on the network? I'm sure I'm missing a step, but I think I've followed all directions perfectly and can't get anywhere.
    Thanks for your advice so far!
    You really need to turn off the wireless network adapter on your computer while trying to get into the camera. Try that and let me know if you have better results.
    Set the network adapter back to default and plug the camera back in.
    Right click the two computers and select status.
    Click (support)
    Click (details)
    What if anything do you see next to the default gateway xxx.xxx.xx.xx?
Trendnet TV-IP501w camera will display images/video on IE at home, but not offsite. This is 64-bit Vista. Turning off the firewall does not help. Offsite, all I get is ip# not found or a timeout message....
1st you need the ip of the camera in your network at home
then you have to go into your router at home at forward either a specific port range of ports or all ports to that Ip address of camera.
you will only be able to access it remotely after all this is done.
portchecker.com
canyouseeme.org
Aug 06, 2011 | Trendnet Tv-ip501w Proview Wireless...
I have a dual band netgear router N 300 series. i have just purchased the trendnet adapter and opened it from the box. i followed all the steps for setup to to "t". The adapter is able to connect...
yes, the g based adapter is only compatible with G networks not N. You can fix your problem by logging into your router and changing the advanced setup options so they accept the G Based adapter.
Jan 08, 2011 | Trendnet TEW649UB Mini Wireless N Speed...
Wireless function on camera does not work. I foll...
SSID is case sensitive. Make sure you select the correct security settings. Wireless Mode has to be Infrastructure. If it is still not working try upgrading to the latest firmware version
May 20, 2010 | TRENDnet SecurView TV-IP121W Day/Night...
I can not access the setup of my camera trendnet TV-IP110W since Internet Exporer
  1. Please make sure if both the camera and computer is connected to your router's LAN port
  2. Open the IPSetup Software which came on the CD along with the product
  3. It will detect the camera's current IP address. You can change it to an IP address based on your network
  4. The double click on that IP address or type it on IE's address bar. Camera's Live view will be shown up
  5. Then you can match the wireless setting with your wireless router to view the camera wireless without being connected by a Ethernet cable
May 15, 2010 | Trendware TV-IP110W Network Camera
Where is the reset on hp r707 digital camera
There is no reset button on this camera. For reseting it follow these steps (from the MANUAL, page 122):
1 In the Setup Menu , select Reset Settings....
2 In the Reset All Settings? sub-menu, highlight one of these
two choices:
? Cancel ? Exits the menu without resetting any of the
settings.
? Yes ? Resets all camera settings to their default value in
the Capture Menu and Setup Menu (except Date & Time,
Language, TV Configuration, and USB Configuration).
3 Press Menu/OK to reset settings and return to the Setup Menu.
Apr 07, 2010 | HP Photosmart R707 Digital Camera
I can not access the setup of my camera TRENDnet TV-IP110W since Internet Exporer
Please try with a different brower or try viewing it through the Secure view software which was given along with the camera. Comes on the Installation CD
Mar 28, 2010 | Trendware TV-IP110W Network Camera
Need an operating manual and a start-up disc for a Pixma iP100.
Go to this page:
Canon iP100 Support
If the Drivers & Downloads tab is not selected, click on it.
Under the Guides and Manuals you can download the Quick Start or Easy Setup guides. When you click on the link it will open (as long as you have Acrobat Reader) and then you can save them to your computer for future use.
On that same page, if you select your operating system from the drop down menu near the top, you will get a list of available software.
You will need the software under Drivers. It ends in exe. Click on the file name. You will then have to accept the EULA. When you do you will get another download window. The best thing to do is to select Save and direct it to your desktop. When the download is complete, close the window.
To install the software:
Make sure the printer has ink and paper. Turn the printer OFF and disconnect the USB cable from the computer.
Run (double-click) the file on your desktop that you downloaded. This will begin the install. When prompted, connect the USB cable to the computer and turn the printer ON. This will continue the software install.
NOTE: Should you get any "Found New Hardware" windows, simply Cancel them out.
That should get you going. Refer to the Easy Setup guide mentioned above for additional info.
Thanks for using Fixya.
Dec 28, 2009 | Canon Office Equipment & Supplies
Manual Setup of Trendnet Router
1. Open Internet Explorer 5.0 or above Internet browser.
2. Enter IP address http://192.168.10.1 (the factory-default IP address setting) to
the URL web address location.
3. When the following dialog box appears, enter the user name and password to
login to the main configuration window, the default username and password is “admin”.
Jan 12, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Trendnet Wireless Internet Surveillance Camera TVIP100WN Logo
345 people viewed this question
Top Trendnet Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Trendnet Home Security Expert? Answer questions, earn points and help others
