Question about HP Compaq Presario 2200 Notebook
I have a Compaq Presario 2200. I was using it, plugged in, and unplugged it to move it to another area and now it doesn't recognize that it is plugged in. It is using the battery. What can I do?
    Sergeant:
  • 192 Answers
Remove the battery with the power cord plugged in and see if it will power up for you. If it does not then you have a bad power adapter.
Posted on Mar 21, 2011
Manuel for compaq presario 2200 series 3297
Hi Carol,
Here's the manual in pdf.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | HP Compaq Presario 2200 Notebook
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
I have a Compaq Presario CQ60, and when it is unplugged and I press on the palmrest or move the screen it shuts down. When it is plugged in, it does not have these problems. What is the problem?
Hi!
It is most likely something about the battery connector. Please shut down your laptop, remove the battery and clean both connectors halfs (one on the battery itself, the other on the laptop).
Do not use for cleaning chemicals or water that can damage the plastic parts of the laptop or the electronic parts inside.
I use only a wood tip (because it doesn't scratch the golden surface of the contacts), cloth and pure alcohol.
After cleaning put the battery back in it's place and be sure it is locked.
Hope it helped,
Bogdan.
Aug 28, 2011 | Compaq Presario Notebook
Is there an internal microphone and if so where is it located trying to record myself i have a compaq presario 2200
Hi, the HP Compaq Presario 2200 PC has no built in or internal microphone. You will have to purchase an external one to record audio. The microphone jack, when viewing the laptop from the front, is located on the left side.
There are small round holes which are jack ports. From the front to the back, the microphone port to plug in a microphone is the second hole back. Here is a manual in case you need more help with your laptop: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | HP Compaq Presario 2200 Notebook
Compaq Presario 2200 Severed touch pad cable. When I attached mouse says it needs driver. Is there a sight or does anyone know which are the main keys to control selector without touch pad or mouse ??...
Arrow keys, Enter, Tab, and the Windows key are the main control keys. However, Windows should recognize any generic USB mouse you plug in, and automatically install the drivers for it.
Mar 24, 2011 | Compaq Computers & Internet
Does the Compaq Pressario 2200 notebook have a built-in microphone?
no built-in microphone of your laptop but you can use microphone by plugging it to microphone jack
Oct 12, 2009 | HP Compaq Presario 2200 Notebook
Microphone muted on compaq laptop presario 2200
first u plug in micro phone then u displayed the setting of microphone and then turn off mute
Oct 01, 2009 | HP Compaq Presario 2200 Notebook
Laptop not powering
try a simple power cycle. Take out the battery, leave power adapter plugged in. Hold down the power button for about one minute. Then hit the power button normally this should correct the problem
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Compaq Presario 2200 won't hold a charge - on or off AC
I have a Compaq Presario 2210US. The wireless toggle button is in front on the right side, slightly under the top of the computer. Feel for it with your fingers or use a flashlight. It glows a bright blue when on.
Oct 30, 2008 | HP Compaq Presario 2200 Notebook
Installing a wireless card in my presario 2200
The easyest way would be to buy a USB wireless adapter.
You just plug it in install the software and thats it.
I'm useing a TPLINK USB adapter, it cost me 20 €
You can also use a internal card, Mini pci most likely. very simple to install also but you might have signal - antenna problems. But this tplink has worked very well in my home and in the city.
May 17, 2008 | HP Compaq Presario 2200 Notebook
HP Compaq Presario 2200 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
