Question about Planet Audio AP1000D Car Amp
Ap 1000 amp checked wiring ground ect . the amp comes on when i turn the radio on at no volume and beats steady for no reason jumped remote wire same . plugged audio jacks and the same . please help
  • 655 Answers
The most common problem for the symptom you describe is a "ground loop". There's a slight difference in the ground potential between the source unit and the amp itself. It may be caused by a ground on one or both of the audio inputs. It may be caused by the amp case itself being fastened to a metal portion of the vehicle. It may be a grounded speaker lead.
Of course the amp itself could be defective.
1) Isolate the problem. Disconnect everything except power, ground, and remote.
2) Connect the subwoofer(s). If the symptom immediately returns, it's most likely the amp ground or a speaker lead.
Posted on Mar 21, 2011
  • 2 more comments
  • cragerboy539 Mar 22, 2011
    yeah but how can i tell if the speaker aint hooked up
    and check this out cant be a speaker lead if the audio jacks are off of it thats what kick over the amp to play the subs . saying the speakers get no wattage if audio jacks aint sending signal. cuz it makes bass for no reason when audio jacks aint hooked up right . the remote wire just makes the amp come on .
    the word right was aimed to you meaning aint i right
    hate to add to it but my amp isnt fastened to any metal . leads to box isnt touching anything .
I have a kenwood jvc kdc-x597. i can't get my amp to turn on. Do I have to have the radio set for sound to come out of all speakers inside car for remote wire on head unit to work?
Buy a cheap 12v circut wire tester and see if your getting juce from the remote wire. Also check fuses. If no juse just tap the radio acc wire and run it to the remote amp wire. Also check your amp ground. Infact first bridge your 12v amp + wire to the remote wire with some pliers or a short wire and see if the amp comes on. That will make sure the amp is not the issue.
Nov 05, 2016 | Kenwood Car Audio & Video
Radio on but no sound after installing after market subs
to create a spark you must have had power connected somewhere. Did you have your radio turned on when you connected? if yes you may have blown the amp in the radio. If no then you have other issues with wiring and possible damage.
It's one of those instances where I'd need to be there to diagnose it.
Start by double checking the stereo is working, check its wiring is correct try each speaker connection in turn. If the stereo works and all the outputs work then double check the amps wiring and try a normal speaker connected to it. You must get the picture by now, you need to identify the source of the fault. to help you better I'd need a wiring diagram.
Dec 20, 2011 | 2003 Toyota Camry
I blew the fuse inside the fuse block (60A). I replaced it so now I know I have power getting to the amp. I checked it with a meter and I show 12 volts passing throught the fuse block. I can not get the...
Sometimes there is a fuse inside but they are usually thermal and reset when they cool. You said u blew a 60 amp fuse. Is that what the manuf reccomends? Check your remote turn on wire (blue) make sure u have power on the remote wire when you turn the radio on. only thing really left are the grounds
Jun 11, 2011 | Jl Audio 1000/1 Car Audio Amplifier
I removed the remote wire to change the amp position, and when I hooked it back up, the power light came on for a brief second and then faded out. Not to come back on again
the remote wire might have touched ground... make sure you still have voltage on the remote wire with the radio turned on....another test is jump the main red wire to remote also..
Sep 12, 2010 | Alpine MRP-M450 Car Audio Amplifier
How do i install it it was a hand me down with no instructions
http://dl.owneriq.net/a/a44b260d-f7bb-4ae7-bd9f-5a4722cb9427.pdf
in general
the positive terminal is connected to the positive of the battery
the negative terminal is connected to a metal grounding point on the car ( find a metal spot on the car to connect the negative terminal of amplifier)(do not connect it to the negative side of the battery)
the remote terminal connects to either the remote line from the back of the radio blue and white wire
if the radio does not have a remote wire then use the red wire which is the acc (check this against your car wiring)
the speakers are simple connect the positive of radio to positive terminal ect
and the input comes from the radio as a phono jack connect that to the input of the input of the amplifier right left ect ect also if the radio has only left and right then you need a splitter for the phono cable because your amp is 4 channel
if the radio does not have phono jacks then you need to take the output that usually goes to the speakers and route them to the amp and attach pho no jacks on them
Jan 10, 2010 | Alpine MRV-F357 Car Audio Amplifier
NO SOUND OUT OF SUB WOOFERS I AM GETTING POWER TO THE AMP
the easiest thing to do is check the voltage at the amp, between the red power wire and the black it should be the same as the voltage across your battery under the hood. now turn your radio on and c heck the remote turn on wire this wire is at the amp and is usually blue it should have 12 volt when the radio is on and 0 volts whe the radio is turned off check between the blue remote wire and the black ground wire unhook subs from amp and check the resistance across the speaker terminals with a digital mutimeter, if your subs are 4 ohms then your reading on the meter should be around 4, if it is close to 1 or 0, then it's probibly your subs. if everything is good check the fuse on the amp
Jan 07, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
I have an alpine MRP-1000 and i install the wires well and the
double check all of you wires. Make sure that you have your power, remote and ground from known good sources. Also double check all fuses, the inline fuse for the power wire, the fuse on the amp, and also check the fuse for the radio or where ever your remote wire is coming from.
Mar 31, 2009 | Alpine MRP-M1000 Car Audio Amplifier
PEAVEY AMP
IF IT IS A NEW AMP IT MAY ONLY BE THAT THE REMOTE POWER WIRE IS NOT GETTING THE 12 VOLTS TO TURN ON ....IF IT IS OLD IT MAY BE ANYTHING POWER WIRE GROUND WIRE FUSES ECT... HARD TO SAY...GOOD LUCK
Jan 08, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Rockford fosgate amp 301X- trouble with wiring remote
You may have open shields on the head unit. You need to check continuity between the shield and the case of the head unit. The following page shows you how to do it.
Shield Ground Repair
Feb 20, 2008 | Rockford Fosgate Punch 301X Car Audio...
Remote wire hook up
The Remote wire should connect to the remote turn on lead from you radio(most aftermarket radios use a blue and white or a blue wire for the remote turn on). This wire will send a 12v signal to the amp from the radio when the radio is turned on. You can disconnect the remote turn on lead from the amp and jump a wire from the terminal marked battery to the remote turn on terminal just to see if the amp powers up. Do not leave it this way however because your amp will not shut off and your battery will go dead.
Aug 19, 2007 | Rockford Fosgate Punch 301S Car Audio...
Planet Audio AP1000D Car Amp Logo
97 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
