Question about KitchenAid KWCU205HSS Kitchen Hood
Bought a KitchenAid Wall mount canopy range hood in 2005. (horizontal wall venting) More often than not the motor (what else could it be) makes a screeching noise. This noise sometimes dissappears after a few minutes sometimes continues. This trouble starte about 2 months ago. Thank you very much. Francois
  • francois_aub Mar 24, 2011
    thanks for your prompt response.
    very satisfied.
  • 5,370 Answers
Yes its possible that motor is got dried internally.There is grease in the motor and other parts to make it run fluently, when this grease gets dried out then internal motor and and other motor connected parts gets hard.So it makes noise when it starts, but once it gets flow, the noise gets slow or goes away.But this can cause the motor to get shorted out and even its possible that motor is got weak and needs to be replaced.You will have to disassemble the hood unit and visually inspect the motor,.If it looks very dirty and worn out.Its external body got burned/ rusted then it needs to be replaced.But it only looks dried out then you can lube the internal motor parts by applying motor grease.-------- the noise can also occur from fan motor or jammed fan blades.That also too has to be inspected.-------- For that you will need disassembly diagrams:---- click this link below for hood disassembly:--- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Range-hood-Parts/Model-KWCU205HSS0/0593/0122400/O2029119/00001?blt=06&prst=&shdMod= ------------- Click this link below for vent disassembly:--- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Range-hood-Parts/Model-KWCU205HSS0/0593/0122400/O2029119/00002?blt=06&prst=&shdMod= --------------- This should help.Thanks.Helpmech.
Posted on Mar 21, 2011
Fan is not working but makes a humming noise at lower speeds and clanking noise at highest speed. When last working there was the clanking noise when I turned off the fan. Please help.
Then turn it off immediately just to be safe that nothing will be broken, can you see the interior? Is there anything broken or loose that might cause the noize? If yes remove.
If not try to clean it with a little cloth or anything, maybe it is too dusty.
Mar 10, 2016 | Electrolux RH36WC60GS Designer Glass...
Ge monogram fan dying slow death...first hi-spd. only, now only humming, lights work...is it fuse, transformer or worse, blower assembly
My best guess is the blower motor is going out -- probably the bearings. You might be able to replace just the motor excluding the propeller or the squirrel cage as the case maybe.
Oct 08, 2012 | General Electric GE Monogram 36""...
Noisy range hood
Kit-aid sells blowers that are near silent, call 1-800-422-1230. Have your model number ready and they will get you what you need
Jun 02, 2012 | KitchenAid 36 in. Wall Canopy Range Hood
When buying a wall mounted range hood, do I need
If you are going to use the hood ductless you just need to make sure that it comes with a charcoal filter or buy one at the time. Also you need to make sure the hood can be used ductless.
May 08, 2010 | Kitchen Ranges
Installing a vent hood...
There is no kit to make this conversion. That being said, you could get an estimate from a sheet metal fabrication shop on creating the conversion you are seeking.
Good luck with it.
Feb 13, 2009 | Frigidaire PLHV36W7CC Kitchen Hood
KitchenAid wall mounted stainless steel stove hood (model KWCU285HSS) The florescent bulb stopped working. A new bulb didn't work any better. When I tried to install a new starter I noticed that the...
Hi ahev you took the unti off the wall as you need to do this to be able to acess the internal electrics of the unit.
Did you fit it on the wall or get somebody else to do it.
Their is three screws holding it to wall one either side and one up towards the top let me know if you understand what im going on about
Jan 29, 2008 | KitchenAid KWCU205HSS Kitchen Hood
Hood lights constantly zapping out.
I have a similar unit - KitchenAid wall mounted stainless steel stove hood (model KWCU285HSS). Please let me know if you figure out how to open the thing/canopy up. I'm trying to get into the area above the florescent light & starter.
Spencer
Jan 16, 2008 | KitchenAid KWCU360J Kitchen Hood
KitchenAid KWCU205HSS Kitchen Hood Logo
271 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
