Question about Pioneer AVIC-F700BT Car GPS Receiver
Got this radio second hand. It is installed, powers on, but only function that seem to be available is am/fm radio and cd player. It doesn't have gps antenna just yet have to order one...does that keep it from running other function like blue tooth, dvd, and mp3 player?
    Top Expert:
  • Pioneer Master
  • 77,939 Answers
No those will function without any antenna.
Posted on Mar 21, 2011
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
1995 dodge van stalls. Then will restart later. Seems like an ignition shut off?
It could be an overheading situation with the ignitor coil or the spark arrestor. I have seen this on Chevy Vans as well.
You won't see smoke, as it will just overheat internally and create a break in the electric connections.
Sep 06, 2016 | OEM 1995 Dodge B2500 VAN Radio / CD Player...
No power cord for CDR single disc cd recorder
There are a few common power cords that fit most makes, Radio Shack, Service Shops, Specialty Electronic Stores, and second hand shops usually will have what you are looking for, as a last resort check out ebay.
Mar 06, 2012 | Koss Audio Players & Recorders
XMD3 I bought a second hand boat with this radio , not working , do you have an installation schema ?Thanks
hello there ,firstly at the rear of the radio you will see two plastic blocks top block is your power in )secondly bottom block is your( audio ) sound these wires are colour coded for front and rear speakers ,your dc power which cannot be over 13.8v black and red wire on top block you have a socket to the right this will be for the antenna ,also check the fuse line before switching on hope this helps you
Mar 25, 2011 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
I bought a '96 Mustang with an Alpine CHM 5620 CD player already installed. The unit appears in great shape and looks as if it were installed by a pro. It seems to load up the CD cartridge and change CDs...
This model of cd changer doesn't have the fm modual built into it. So I am wonder how this setup worked before. Most of these units had an FM tansmitter in them and you would just turn on your factory radio and set the fm tuner to a certain frequency like 89.5 or 91.3, not excatly sure on the right number, but somewhere low in the range. Turn on the stero and try tuning into differnet stations.
But like I said this model is desgined to be used with a aftermarket head unit with the proper wired connection going from the cd changer to the head unit.
Sep 21, 2010 | Alpine Car Audio & Video
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Dodge RB4 GPS system
Sounds like the J1850 bus is not connected to the RB4 radio.The speed sensor info is received thru the bus which alows the nav to function and calibrate itself.Or as I have mentioned before, there may be problems on the NAV pcb.There have been many issues with the nav pcb assy.
Jun 23, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Dodge RB4 nav system problem
See my other Posts which refer to this problem.
Gps is not working
I know the is a old post but i will provide some answers to the question.
1 the radio has to be connected to J1850 bus to talk with the sensors in the vehicle
2 check nav ant for broken wire.
3 check nav ant socket (center pin) should have no less than 4.95 volts DC with radio on.
4 Problem more than likely on nav PCB .
I have run across MANY problems on the nav pcb.
May 23, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Pioneer AVIC-F700BT Car GPS Receiver Logo
90 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
