How do i change the cleaning blade - Office Equipment & Supplies
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Dear let us know the model and brand of copier
Posted on Apr 06, 2011
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Wiper blade is squeaky how do I fix it
1) Lift blade and clean with washer fluid on rag.
2) lift blade clean with Fantastic or similar on edge with rag.
3) Bend wiper arm slightly to put pressure on window from blade.
4) Change blade.
Mar 09, 2015 | BMW X3 Series Cars & Trucks
Service manual
Clean or change the drum cleaning blade,check the fuser unit rollers abd the transport belts.Clean the image transfer/separator coronas unit,check ,clean or change the drum antisplit bade,located under drum cleaning blade.
Apr 30, 2013 | Minolta EP1083 CS/PRO Copier
Canon pc735
Clean the image unit componenets,OPC drum and the drum cleaning blade or change the cleaning blade.Clean the laser unit.
Feb 16, 2013 | Canon Office Equipment & Supplies
Print copy white
If the copies is whitw possible causes:
toner empty,not toner
developer drive transmission mechanism failure
image transfer current terminal poor intact
Feb 09, 2013 | Ricoh Aficio 2035 Copier
I am having trouble with loose stitches and my fabric is not being cut by the blade. I have t Cleaned my machine , rethreaded me serger a few times , I have adjusted the tension , I am traveling and I do...
try changing the needles
check the blade to see if it's loose or misaligned or dirty
try wiping the blades,, try using silicon spray or alcohol on them
to clean them.
after you check the blade to see if there loose or not,,
lay a single thread across the lower cutter blade and handwalk the needle through a stitch cycle watching that thread across the knife blade. If the thread cuts clean the blades are sharp. If it moves
forward on the blade, the softer blade is probably dull enough that it needs replacing
Nov 08, 2012 | Husqvarna Huskylock Computerized 910
HOW DO YOU CHANGE A CLEANING BLADE IN A CF900 COPIER
Remove the OPC drum unit,remove the OPC drom and change the cleaning blade(fixed 2 screws).Normally if you change the OPC drum change automatically the OPC cleaning blade.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Need to change cleaner blade on drum
Remove drum unit, remove Drum, remove blade (2 screws)
** coat the new blade with some toner, or it will flip, when the drum start to turn, due to the friction. And always manually rotate it yourself prior to re-installation to make sure it is ok
Apr 28, 2009 | Canon C330D Copier
Toner smudge/how to clean?
Inside the printer there is a piece called a "blade". After a sheet is printed then the blade's job is to run across the toner cartridge and clean up all the toner. If the blade is not working properly then you will get excess toner. So the blade needs to be changed. You can change it yourself, by looking for instructions off of the internet or have a repair shop do it...here is a website just to give you an idea of what I am talking about. Any questions let me know.
http://www.tradekey.com/ks-printer-blade/
Pls rate this solution with 4 diamonds.
Apr 14, 2009 | Office Equipment & Supplies
20 people viewed this question
k24674
jasbo
jasbo
