How do I increase screen resolution in PC mode running Windows XP Pro?
    Novelist:
  • 107 Answers
To change your monitor's resolution
1. Right-click the desktop, and then click Properties.
2. In the Display Properties dialog box, click the Settings tab.
3. Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4. Click Apply to have the new resolution take effect.
5. If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6. Click OKHow do I increase screen - panalow_2.jpgr />panalow_2.jpg
Hope this help.
Posted on Mar 21, 2011
Right click on your Desktop wallpaper and go to Properties. You should receive a Display Properties window. Find the Settings tab. Under the Settings tab is an area for changing your screen resolution.
Alternatively, to get to Display Properties window, you can go to Start button-->Control Panel-->Display
  • 98 Answers
I believe it should be similar to XP Home
On the main desktop, over no icons, click on the right mouse button and choose personalize. Then choose display settings to get to the resolution choices.
  • 72 Answers
Right click on any clear area on the desktop; Select Options; Goto the last tab to change the resolution
How do I get missing Icons back on my PC screen
The higher the resolution, the more likely you will be able to see your icons.
From Microsoft.com:
1. Open Display in Control Panel. 2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply. 3. When prompted to apply the settings, click OK. Your screen will turn black for a moment. 4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting. Note
• To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display. • A higher screen resolution reduces the size of items on your screen and increases the relative space on your desktop • You can switch your screen resolution temporarily to 640 X 480 if you have games or other programs that are set to run at that resolution. To switch, right-click the game or program (on the desktop or on the Start menu), and then click Properties. Click the Compatibility tab, and then select the Run in 640x480 screen resolution check box. Your display reverts to its default resolution when you close the program. • Your monitor and video adapter determine how much you can change your screen resolution. You may not be able to increase the resolution above a certain level. • Changes to screen resolution affect all users that log on to the computer. • Only the recommended screen resolutions are listed. For additional settings, click the Advanced button on the Settings tab, click the Adapter tab, and then click List all Modes. Select the resolution, color level, and refresh rate you want.
May 28, 2016 | Microsoft CompuRegister POS-1000 POS...
Display Resolution for Compaq Presario Upgraded XP to WIndows 7
not its possible.... that resolution come with the LCD of the laptop and the only way its buying a lcd screen that support more resolution.. Pls click if my solution was helpful
Dec 28, 2009 | Compaq Presario Notebook
Monitor Resolution
You have to update you VGA drivers.
Jul 26, 2009 | Computers & Internet
Latop d620 worked ine but now screen is lack unless in safe mode
Now I don’t know how unplugging it or moving it would cause that problem but it does sound like you might have an issue with the refresh rate and or screen resolution at a setting that is to high for the screen to display (safe mode only loads windows core components and minimal set of drivers like basic vga driver for display which is why it probably works in safe mode)
If you are running windows XP then try the following:
Ok try hitting F8 key before XP logo appears for boot menu then select "enable vga mode" then after you get to a desktop go to display settings and lower the screen resolution and refresh rate setting
(refresh rate should be at 60hz) resolution could be different depending on which screen you have there... but try 1024x768 just to be safe then reboot into normal mode and see if it works and if it does then you can adjust the resolution to what it was before problem occurred
If you are running Windows Vista then boot from the Vista CD and select “repair my computer” and then “fix startup problems” and it should do it for you
May 16, 2009 | E-Machines M5310 Notebook
My problem is the displayed windows on my monitor/screen
Press the F8 key when windows is booting up from a power off situation, select "safe Mode" you should get a Display then,(NO Video driver(except windows generic) driver is load in safe mode). Set your display to the LOWEST resolution.. Reboot. See if you have a display with the driver set Low. If so, increase the resolution on level at a time until you encounter a problem. If you do not select Yes when windows asks if you want to keep this display setting, Windows will revert back to the last setting you selected yes for.
Apr 12, 2009 | Microsoft Windows 2000 Professional for PC
Out of range external monitor
The max resolution supported by that LCD HDTV is 1366 x 768. If your screen resolution in XP is set higher than that, you'll run into issues. Reduce your screen resolution first, then run the nVidia multiple display setup.
Jan 28, 2009 | IBM NetVista PC Desktop
Can't increase resolution above 1024x768
try the radeon igp 350m driver ,I use this on xp pro ,many res choices.
Apr 09, 2008 | Dell Latitude C640 Notebook
FUJITSU SIEMENS AMILO PRO V2000D
Hi
It sounds like Drivers for the Video card is not loaded properly.
What is the current screen resolution?
Are you able to increase the resolution to say 800 x 600 pixel or preferably 1024 x 768 pixel?
If the current screen resolution is 640 x 480 pixel and you are unable to increase resolution to the above pixel levels, try updating Windows Drivers for your video card.
AMILO Pro V2000 Display - Intel® 82852/82855 GM/GME Graphics Controller Family (Intel® 852/855 Chipset Family) (WinXP, W2000) Version: 6.14.10.3792.
Directly download - http://support.fujitsu-siemens.com/download/ShowDescription.asp?SoftwareGUID=325da0bd-fe5f-41e6-84d9-d628c5411188&OSID=665F4A20-6E31-43C3-82C2-D98CE773007C&Status=True&Component=Intel%20855GM
Regards
Mike
Mar 18, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
FUJITSU SIEMENS AMILO PRO V200D
Hi
Regards
Mike
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
352 people viewed this question
David Payne
David Payne
