Question about Riccar Sewing Machines
I can't the bottom thread to pick up - Riccar Sewing Machines
  • 415 Answers
Check to make sure you have the right needle (different brands sometimes require different kinds) and make sure it is put in right, ie not turned around backwards
Posted on Mar 22, 2011
Top thread not picking up bottom thread
Try installing a brand new needle. Bent or damaged needles sometimes do not contact the bobbin thread to pick it up.
Usually threading is not an issue, but you may want to rethread the machine (be sure to always RAISE the presser foot during threading).
If it still doesn't pick up the bobbin thread, most likely the needle/hook is out of time. Take it for service.
Jun 04, 2016 | Sewing Machines
Singer model 629 wont pick up bottom thread
If your needle isn't picking up the bottom thread, lower your needle just a bit. Only the top of the needle head should be up inside the shank.
Aug 31, 2013 | Sewing Machines
PE-3000S Pacesetter won't pick up bottom thread
try changing the needle
also rethread the machine
clean under the needle plate & in the bobbin area for loose threads or lint
if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
May 15, 2012 | Brother Sewing Machines
Top thread is picked up by hook, but never picks up bottom thread. I know how to adjust needle height. How do I adjust hook timing?
try turning the bottom spool upside down. looking at the shuttle in your palm the thread needs to be on the left hand side winding / facing anti clockwise to catch in the hook see link below for
instructions:
Nov 09, 2010 | Brother LS2125i Sewing Machine
Bottom thread not picking up for 4500 series,,,tried new needle.new bobin,new thread,,pliz help
The most common reason the bottom thread won't pick up is because the needle is inserted wrong. Check that the needle is inserted with the flat side of the needle shank is facing away from you.
Robbie
Aug 09, 2010 | Toyota SE-06 Mechanical Sewing Machine
Top thread doesn't pick up the bobbin thread (Toyota sewing m.)
Hi! This may sound silly, but if you changed your needle and put it in backwards (which is easy to do), the top thread won't pick up the bottom thread. Take your needle out and check the flat side of the needle shank--which way is it facing? With a lot of the newer machines, the flat side goes to the back, but check your manual to make sure.
Let me know if this helps, ok?
Happy Sewing!
Robbie
Feb 12, 2010 | Sewing Machines
Not picking up the bobbin thread
Make sure the needle is facing the right way. If it's in backwards it won't pick up the bobbin thread.
Jan 04, 2009 | Baby Lock Esante
Top thread doesn't pick up bottom thread.
I have tried different length of needles and it started once length was right.
Oct 06, 2008 | Euro-Pro 7535 Mechanical Sewing Machine
Singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Dec 15, 2007 | Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
