Question about Whirlpool Duet GHW9150P Front Load Washer
My washer starts lets shuts down with a code of f5
  • 403 Answers
Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Potential Causes
•Check the Water Temperature Sensor, Heating Element and Element Relay
•Check connections to the Sensor, Heating Element and Relay
Posted on Mar 21, 2011
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
Have a Kenmore 110.2632410 top load washer. Getting error code F5. Lid lock is just clicking.
The F5 error code indicates that the Central Control Unit (main machine control board) detects a temperature sensor resistance that is out of the normal range. The F5 error is normally caused by a failed NTC temperature sensor.
Jul 17, 2016 | Kenmore Washing Machines
F5 error code
http://www.shopyourway.com/questions/1083064
see above link, apparently you need a water temperature sensor check
Jun 15, 2015 | Washing Machines
What does error code f5 mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Read more: http://forum.appliancepartspros.com/washer-repair/244131-error-code-f5-model-11045087404-kenmore-elite-residential-washer.html#ixzz34ySdUUeZ
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
It stops it beeps it flashes F5 it's a whirlpool duet front load washer
When this happens press and hold any key down for one minute to clear f5 code
Apr 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Why won't the oven door lock to start the self cleaning? The door appears to be shut all the way. After hit start, this code appears E1 F5
According to the Whirlpool website, the self-cleaning latch may be interfering with the door, though this would be indicated by an "E0 F5" error code. If that's the case, Whirlpool recommends the following:
1) Press "Stop/Clear" to clear your display.
2) According to Whirlpool, there should be a door switch plunger in the upper right corner of the oven front. Press and hold this so that the door latch will unlock.
However, if it is indeed "E1 F5" (or any other number with those letters in the code), Whirlpool recommends calling an appliance technician.
http://whirlpool.custhelp.com/app/answers/detail/a_id/319/kw/error%20code
Feb 28, 2011 | Whirlpool Kitchen Ranges
Fault code F5 & P10 on Ferroli opimax he 31c boiler
my air cond runs for 20 minutes than shows f5 and shut down compressor
Dec 02, 2010 | Heating & Cooling
Problem on touch pad
something has not finished uninstalling
right click my computer then properties
hardware and then device
scroll down device manager if you see anything with ? or !
right click and update if it is something your trying to remove then click to uninstall to finish removing
if that does not solve then follow instructions below
Wait several seconds, and then press the F5 key to update the Device Manager view. If that does not resolve the problem, restart your computer. Click Start, click Shut Down, and then select Restart in the Shut Down Windows dialog box to restart the computer.
please let me know and please rate
Feb 12, 2009 | Acer Aspire One PC Notebook
How do you fix error F5?
"F5" is a temperature sensor error. The following link explains how to diagnose and correct:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
The first thing to try, however, is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches. If the error code reappears, then you know you have a legitimate error. In many cases, the small connector that plugs into the heat sensor either becomes corroded, or comes loose. Make sure you troubleshoot the washer while it is UNPLUGGED.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Sep 23, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
274 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
