How do I set MultiTech Atomic CLock? There are no directions
5 Suggested Answers
SOURCE: Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Posted on Apr 30, 2009
SOURCE: I can't set the clock. The hands keep turning and
Look at the bottom right of the back of the clock and find the "M Set" button. Simply hold it down and the clock will move (very slowly). When it gets to the correct time, let go of the button. After that, the radio controlled shoul dcontrol should correct any minor differences in time.
Jim
Posted on Aug 11, 2009
SOURCE: mt atomic clock is always 2 hours slow no matter
How to Change the Time Zone
Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
Posted on Nov 14, 2009
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Posted on Mar 14, 2010
Setting clock on 2N5 VOO(U)
Hello, AB -
Are you asking for instructions for setting a SioScan atomic clock, also called a SkyScan atomic clock? If so . . .
The information here may prove helpful:
https://www.hunker.com/13410966/how-to-reset-the-time-on-the-sioscan-atomic-clock
Best wishes.
Jan 16, 2018 | Home
How can I set the time?
Once you select the time zone and whether you are observing DST, the clock sets automatically. That's the point of having an atomic clock.
Apr 19, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
How do I reset the clock following battery change.
Please go to your browser and type in the information line Atomic Clock directions. All of the companies that produce this type of clock are listed. I believe SKY Scan has its directions ready to be opened when clicked on! GOOD LUCK!
Jun 26, 2014 | SkyScan 86709 Atomic Wall Clock
I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
Hello
Get into this link. You can see the user manual for your Skysacn atomeic clock here. You can adjust your clock according to it manual. OK.
http://www.atomicclocksstore.com/skyscan-atomic-clock-manuals
Nov 11, 2011 | SkyScan 86709 Atomic Wall Clock
My clock jumps an hour ahead, how do I fix it?
Make sure that you have the clock set for the correct time zone, and that the DST feature is switched ON. If those settings are correct, try replacing the batteries. Weak batteries frequently cause an atomic clock to "jump" one hour in either direction.
I hope this helps.
Bill B
Aug 04, 2010 | Honeywell RC182WR Atomic Alarm Clock - Red
How do I set my skyscan atomic clock
You don't. Just make sure that the rear switches are set for the correct time zone, and that the DST switch is set to the ON position (unless you're in an area that does not use Daylight Saving Time). Make sure that your batteries are fresh, and situate the clock so that the front (or back) is facing roughly in the direction of Ft. Collins, Colorado. Give it a couple of hours to find and sync with the time signal, and it will set itself.
Bill B
Jul 02, 2010 | SkyScan 86709 Atomic Wall Clock
I have a atomic clock and dont know how to set it
I have a skyscan Atomic clock model no 86730 and can't set it, every time i get it set, it goes back 1 hr, i need to know to set it to daylight savings time
Mar 17, 2010 | SkyScan 86742 Digital Atomic Wall Clock
AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
63 people viewed this question
 Grubhead
Grubhead
