Question about B&K Reference 200.2 2-Channel Amplifier
I have a reference 200.2 B&K, and I am looking for a service manual or a diagram circuit, for checking its operation. the problem started with a left channel not working and then the sound started to become lower in the right and a little bit distorted and loosing high sounds, becoming a sound with no middle or high notes: to much bass but at lower range. I revised internal fuses and speaker fuses, changed some and the problem persist, although the left started to work but the sound continued low and not clear; I do not know if I have to replace the line fuse also ( could be possible that such fuse be damaged and cause a different voltage to the amp and influence its operation? ) fuse line is a 250V 12 A, time delay ceramic fuse. I do not know if a damaged time delay fuse (even line or rails) while not completely blown still permits working the amp but not efficiently. I live offshore the US and in my country there is no a B&K dealer nor a service for this brand, that is why I am looking for diagrams for getting technical support in my country. Best could be send it for service in the US but it is an expensive and the last resource. Please give a clue for checking my system. (a B&K PT5 preamp and a pair of Martin Logan Speakers -Aeon- complete the system) Thanks for th ehelp. Estuardo
3 Suggested Answers
  • 49 Answers
SOURCE: b&k amp st 2140
There are a few fuses inside the amplifier. The case lid will come off pretty easily once you remove all the screws. You can visually inspect fuses looking for the blown one (filament will be broken), or use a multimeter for ceramic fuses. However, the fuses in my B&K ST-1400 do have transparent cases. If once you replace the fuse, it blows again, then that would suggest an underlying problem.,
Cheers Jeremyt
Posted on Jan 30, 2010
Grubhead
  • 5309 Answers
SOURCE: no problem, just advice, have
With these it all depends on your budget. Some shops will let you try them out for the best results also. If you are in the UK have a word with the guys at Richer Sounds, they will sort you out. Elsewhere try and find a place that will let you try before you buy. After all it's all personal choice, your hearing isn't the same as me or anyone else's.
The link will take you too Richer if any good to you.
http://www.froogle.richersounds.com/products/hi-fi-separates/accessories/hifi-interconnects
Posted on May 25, 2011
Cost for a 200 amp circut breaker
Any home supply store can give you the local cost. An additional cost will be even greater than just changing breakers. You must also change out the incoming service drop conductors. There may also be a need to have the power company's transformer supplying you home changed out. Check it out to be sure.
May 31, 2014 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Crouse - Hines Murry Style MP or MD 200 Amp Main Breaker Difficult to Reset
A 200 amp circuit breaker has a large spring to assist in rapid opening and closing a load of this size to minimize damaging arcing every time is it operated under electrical load
The larger the circuit breaker is and the more poles (1, 2 or 3) that are being opened / closed; the more force it will require to operate - both by hand or when tripping. Compare the tension or force you need to apply to a similar sized circuit breaker at Home Depot, etc.
The troubling issue about this for me is the fact that the 200 amp service disconnect / main is tripping. This is an indication of an overloaded panel / circuit. I usually see individual circuits that trip in a panel - but often find the that main breaker has only 20% - 60% of its rating on it at any given time. If you're tripping a 200 amp service disconnect / main breaker repeatedly - something has got to give - and eventually the circuit breaker will fail. That may be where you are now with this breaker. You may be in need of a service upgrade (if it is the service disconnect) as clearly, you have out grown the 200 amp size one you currently have or need add a new sub-panel to ease the load that this 200 amp main is trying to supply now.
Either way, you should call a reputable electrical contractor to have your service / sub-panel evaluated very soon. Good luck!
Feb 21, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
I need CDI unit circuit diagram for bajaj pulsar 180 or 200
Hi, Ganesh I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
bajaj pulsar 180 wiring diagram Google Search
wiring diagram of bajaj pulsar 135 book results
DOWNLOAD Bajaj Pulsar DTSi DTS UG 180 Service Repair Workshop Manual...
http://www.marutibajaj.com/pdf/Pulsar%20180%20ug3.pdf
http://ondoc.logand.com/d/1735/pdf
Feb 21, 2013 | Bajaj Motorcycles
Wiring diagram for three phase power with two 200 amp service boxes inside building
This work requires a license (or qualified person) everywhere that the National Electrical Code is enforced.
If you're asking how to wire a single phase 200 amp panel from a larger, 3 phase panel of the same voltage - ONE way is to install a 2 pole - 200 amp breaker into the 3 phase panel. Provide 4 correctly sized conductors with the correct insulation in a cable or conduit between the 3 phase panel and the 200 amp single phase panel. Two of these conductors should be black and red (for 120/208 volt system) and connect to the 2 pole - 200 amp circuit breaker terminals, the third should be white and connected to the neutral bus bar. The forth should be green and is connected to the neutral bus bar as well but *only if* it is "service equipment" If it is a "main or sub panel", the green wire should be connected to the ground bus bar. The other end of the conductors should be terminated in a "main lug only" 200 amp panel. The back and red connect to "line 1" and "line 2" bus lugs, the white to the neutral bus bar that is NOT electrically connected to the panel enclosure (do not install the screw or strap between the bar and enclosure). The green must be connected by installing a separate bar that is securely fastened both mechanically and electrically to the enclosure for ground connections.
There is a great deal going on here - and plenty of variables that can change how to do this work, safely and correctly. This is an example of just ONE of many different ways to do the work for a particular installation. There is no one way that works for all situations. If your situation does not support this method - you will have an unsafe installation and subject the building and people in it to a dangerous fire / safety hazard.
Please, consult a licensed electrician before attempting this work.
Nov 17, 2011 | Square D Qo 200 Amp 40 Circuit Indoor...
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Jan 17, 2011 | Arcam AVR-200
Looking for a wiring diagram for yamaha bw 200 1984 having trouble getting it started. the values of the coils would be of help also...
Hi!!
I got a better one for you, click on the following link to get a FREE SERVICE MANUAL for your YAMAHA BW 200 1984.
Have Fun!!
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Oct 29, 2010 | Yamaha DT 125 R Motorcycles
I bought a Generac 17kw with automatic transfer switch. I would like to use a 200 Amp manual throw transfer switch. The generator came with a pre wired sealtite pig tale and junction box. Inside the...
If you are using a Manual transfer switch, then you should manually operate the system. Why don't you use the switch it came with? Why would you use a 200a manual transfer switch on a 17kw generator? The idea is to move your critical circuits into the transfer switch panel. Then it would operate in auto.
Jul 02, 2010 | Generac Guardian 200 Amp Transfer Switch...
Diagram x1000d
http://www.mtx.com/caraudio/products/manualsQuickInstall/amps/XT_1000XD_InstallSheet.pdf
THIS LINK WILL TAKE YOU TO THE SUPPORT PAGE FOR THE 1000XD. IF YOU WERE REFERRING TO THE SERVICE MANUAL OR SCHEMATIC OF THE CIRCUIT BOARD, THEN YOU WILL HAVE TO CONTACT MITEK AT 800-225-5689 AND ASK FOR MR. DABBAS. LET ME KNOW IF YOU REQUIRE FURTHER ASSISTANCE......V
Jan 13, 2010 | MTX X Thunder 1000XD Car Amp
B&K Reference 200.2 2-Channel Amplifier Logo
122 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
