Question about Mtd Garden
I have a lawnflite 920 ride on mower and cannot get the back wheel off to change a flat tyre. I have removed bolt at front, but the wheel won't budge, is it seized or do I need a special tool?
  • 3 Answers
SOURCE: troy bilt riding mower
Have you tried checking your fuel filter or your air breather?
Posted on Dec 09, 2008
  • 68 Answers
SOURCE: We just bought a Series 430 push mower --- had no
They usually put spring washers in there to keep things tight.
Try some good penetrating oil on the pivot bolt.
Last resort--loosen the bolt, use oil on it, retighten.
Posted on Apr 26, 2009
  • 67 Answers
SOURCE: wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Posted on Sep 01, 2009
mowerman1857
  • 389 Answers
SOURCE: flat front tire need to remove from craftsman
Remove the plastic dust cover, remove the E clip holding it on the spindle, remove the spacer/thrust washer, slide wheel and tire of
Posted on Sep 14, 2009
  • 89 Answers
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Posted on Nov 04, 2009
How to remove the rear wheels from a mtd lawnflite ride on mower
they just need bumped off after the bolt is removed .they will be rusty so some penetrating oil will help a lot
Feb 17, 2015 | Mtd Garden
Change front tyre on tractor mower
Hello, Some times it is easier to just remove the tire from the wheel.
Aug 17, 2014 | Husqvarna Garden
Back tyre removal
Most a e-clip holding tire on. I use a tubeless tire repair kit. Blow the tire up, find the leak and use kit repair.
Jan 01, 2014 | Husqvarna 23HP VTwin Hydrostatic 48" Cut...
Remove wheel husqvarna mower
Why do you not just pull the tyre off the rim on the outer side & check fot what caused the puncture/leak... Check the tyre valve first....
Dec 09, 2013 | Garden
I have a rear flat tyre on my lawnflite mower,does the holding bolt on the wheel undo clockwise or anti clockwise?
the bolt comes off counter clock wise but if the bolt is stuck the wheel will be also i just change them right on the mower
Apr 23, 2012 | Garden
How is the stearing adjusted?
There is no adjustment on these mowers. One or both front wheels have been bent backwards by bumping into things. They have to be bent back to the right place again. This isnt easy. When both wheels are pointing forward they should point inwards very slightly.(toein) The steering wheel is centred by pulling the plastic centre off undoing the 1/2" bolt ,pull off the wheel and put it back on where you want. And make sure all the tyres have 12 psi. Cheers
Jan 28, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
170 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
