Question about Macally Bluewave BlueTooth Wireless Stereo Headset for iPod Wireless Headset
Macally Bluetooth Wireless Headphone LED Light Problem
My headphones worked perfectly when I received them, but now when I turn on the part that connects to my ipod, the LED light is a solid pink instead of a flashing blue and no sound comes from it. My headphones still work fine.
  • 3 more comments
  • rlq1667 Oct 13, 2008
    It just stays solidly pink, and it worked fine for a couple of days.
  • lucentdream Oct 14, 2008
    Exact scenario here. Pink, no flashy, no connection, no audio.
  • emihack Nov 17, 2008
    I have the same problem please help meeeeeeeee!!!!!!!!!!
  • dunanadunana Jan 11, 2009
    help!
  • pcosti67 Mar 01, 2009
    if someone find the solution of this problem, please post the answer !
3 Suggested Answers
  • 10 Answers
SOURCE: blue wave wireless headphone
Please take out the batteries from the dongle and headset for 20 minutes.
Insert a new battery into the dongle, plug into your player and turn it on.
Wait for 2 minutes, insert another new battery into the headset and turn it on.
It will take about 2 minutes to connect each other at first time.
Posted on Jan 03, 2008
SOURCE: Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Posted on May 30, 2009
How do i pair HP500BT with device
After charging, turn on headset by pushing the power button until the charging led turns red and flashes. continue to hold the button until the light flashes red and green. Go to your phone or device bluetooth settings page and search for devices, it should show up as TPRO HP500BT. Select device and select to Pair with this device. The light should start flashing red really fast, then it should be paired!
Dec 28, 2013 | Technical Pro HP500BT Wireless Bluetooth...
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
How do i connect my backbeat 903 to my phone
Pairing Your Headphones and Phone/Device
1 Turn on your phone’s or device’s Bluetooth® feature.
2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
See your phone’s or device’s user guide for more information.
4 If prompted, enter 0000 for the PIN code/passkey.
Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
(from plantronics web site)
Apr 04, 2010 | Altec Lansing BackBeat Plus Mobile ...
Can i use any wireless bluetooth headset for xbox 360?
Sorry, but you can only use the microphones that Microsoft has made for the the Xbox 360
Jul 13, 2009 | Insignia Bluetooth Wireless...
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
Blue wave wireless headphone
Dec 14, 2007 | Macally Bluewave BlueTooth Wireless Stereo...
Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Nov 27, 2007 | Logitech Bluetooth Wireless Headphones
Macally Bluewave BlueTooth Wireless Stereo Headset for iPod Wireless Headset Logo
Top Macally Radio Communications Experts
eradiostore
eradiostore
Are you a Macally Radio Communication Expert? Answer questions, earn points and help others
