Question about Sony DHC-MD333 Shelf System
I lost the FM Antenna, is there any way I can get one?
    Guru:
  • 276 Answers
Posted on Mar 21, 2011
There is no electrial retailer in bendigo that has fm aerial to suit this is why i am asking you
Make your own.
  • How to Make an FM Antenna: 8 Steps (with Pictures) www.wikihow.com/Make-an-FM-Antenna
    • 832K VIEWS
    2016-01-11 · How to Make an FM Antenna. Improving the reception of commercial FM radio (88Mhz - 108Mhz) can be done by you at home, simply by replacing the antenna ...
  • Simple FM Radio Aerial - Robert Sewell www.robertsewell.ca/yahoo/fmaerial.html Simple FM Radio Aerial A simple FM radio aerial can be made using about 5 feet of old 300 ohm TV downlead, an alligator clip and some hook-up wire.
  • Or try Jim
  • Antenna Installation Bendigo
    May 23, 2016 | Audio Players & Recorders
    AIWA CX NA909 w/SXWNA 909 Speakers. Just hooked up for a friend that has been idle since a move 1 1/2 years ago. Can only get one FM station only. No AM at all...suggestions. Ralph
    I guess you answered the question right then....., you need the antenna. If you've lost the antenna, I'd suggest a piece of wire, not too thick though...
    As for the AM, that uses a loop antenna, so you might have difficulties with that one.
    Oct 07, 2012 | Aiwa Audio Players & Recorders
    FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
    If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
    What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
    Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
    Sep 14, 2011 | Denon DRA-37
    FM Reception with Jensen MSR3007
    I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
    May 31, 2009 | Jensen CD400M CD Player
    I LOST THE ANTENNA FOR JEEP WRSS 3A BOOMBOX
    I have the same boombox and lost my antenna. I ended up going to my local Walmart and bought a generic rubber moulded car antenna. The studs that came with the antenna had threads and too large of a diameter so I carefully filed/ground the threads down until I acheived the correct diameter necessary for the antenna stud to slip into the antenna receptacle. It works great and looks as if it came with the radio to begin with. I hope this helped!
    Apr 22, 2009 | Jeep JX-CHR Boombox
    FM radio intermittent static on '95 volvo 940
    Sounds like you either left something loose or lost a piece of shielding. Was there a filter on the antenna that you forgot to put back on?
    Jan 10, 2009 | 1991 Volvo 740
    Teac Receiver lost AM and FM
    Well, if your unit had that happen, it sounds like it is possible. ;)
    I would imagine that the radio, like all the other inputs, is in itself a separate unit or circuit board. If something fails on it, it probably wouldn't harm other inputs or the actual amplification itself... just a guess on my but it makes sense. A repair shop could probably open up the case and visually inspect the tuner circuits to make sure there isn't a short or dead something somewhere.
    If there is still sound in Jim's case, I would try a different antenna and/or make sure its hooked into the correct antenna hookup. if sound but antenna change doesnt help, it could still be an internal but maybe simply problem.
    i'm no pro but that's my 2cents
    Oct 29, 2007 | Teac AG-V8060 Receiver
    XM Roady2 Built in FM Modulator not working
    It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
    Feb 01, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
    Sony DHC-MD333 Shelf System Logo
    57 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
