Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fridge part not cooling but the freezer is fine
    Habit-Forming:
  • 17 Answers
Sounds like one of the fans aren't working. The fans only work when the both doors are shut. Shut one door and use a strong magenet on the magenetic sensor ( located on where the door shuts in between the two doors. Shaped like a lump that sticks out). Put your hand to the back wall of the fridge (or to the fan in the freezer) and see if there is air movement. Is there isn't then its the compartment your in's fan.
If they are both working then it could be your freezers de-ice element not working or your fidge my need to be switched off to defrost
Posted on Mar 22, 2011
  • 27 Answers
SOURCE: fridge not cooling
Check and see if your evaporator fan motor is working in the freezer. Also, if your defrost system is not working and your evaporator coil is frosted up, you will not get any cold air to the refrigerator section. You should see alot of frost on the back wall of the freezer where the evaporator coil is located. If your evaporator fan motor is working and there is no frost build up on the coil, the air diffuser to the refrigerator section may be the problem. Put your hand in front of it when the evaporator fan motor is running and feel if any air is coming thru. There are a number of conditions that can cause your problem. This should get you started! Visit me on Ebay as username: themackshack. Good luck! Mack
Posted on Mar 23, 2008
SOURCE: have Vestfrost Fridge/Freezer was shut
I have the sample problem, Dan in NJ Same exact problem as danilyn....ugh
Posted on Aug 07, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Fridge not cooling
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Posted on Jun 21, 2009
SOURCE: My Whirlpool cb18m Fridge Freezer works fine but
check to see if the evaporator fan is working in the back of the freezer panel
Posted on Jul 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
I have a fridge that was made in 1995 that the fridge stays warm freezer works fine I also can not fine a model @ that I can read
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Kenmore Top Freezer Refrigerator
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
My freezer works fine, but the fridge doesn't
The air channel from the freezer to the fridge is probably blocked. Give it a full defrost to melt the ice from the cooling fins inside the freezer walls.
Mar 20, 2009 | Refrigerators
Fridge part of fridge freezer not cooling
heatman101
Aug 16, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
131 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
