Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Have a DC04 and the handle has broken off in a fall. Can it be replaced-what Part No. and cost
Kirby G3 handle spring not working , handle falls down
you need to replace the handle pivot assembly, cost about 25-30
Feb 24, 2017 | Kirby Vacuums
Machine wont stay standing bag and handle falls down
the detent is broken. Usually only costs about $8 for the part and maybe 15 to put it in, but it depends on the make/model. Or you can just lean it against the wall...
Nov 08, 2013 | Riccar 8955 Upright Vacuum
The cylinder on my Dyson DC04 (silver/lime) is stuck on. It was OK yesterday when I emptied it.
VERY gently tap it with a non-metal object, like a wood handle or something to see if that will loosen it up. Then, try using a flat-edged screwdriver to pry it loose from it's base, but VERY gently, so as not to damage it.
Oct 18, 2013 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dc04 on off button
This video will give you full instructions how to remove switch to change cable
and here are pictureshttp://www.dysonmedic.com/DC04%20Folder/DC04%20Cable.html
Dec 12, 2012 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dyson dc04 new belt snapping and I think the brushroll is broken as only part of it rotates when i manually turn it
I'm sorry to hear you're having difficulties with your DC04. From your description of the issue, it sounds as if it's probably best if you get in touch with us directly so we can determine if a replacement part is necessary. You can call us free on 08002980298 - our Helpline is available from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 23, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
DC04 Handle broke on grey cyclone top. I have a new top and need to remove the yellow central cyclone cone from the old one in order to refit in the new one. How do I do that?
Unfortunately we can't supply instructions on how to dismantle the cyclone assembly. However if you wish to purchase a replacement cyclone assembly, you can do so via our online store:
http://www.dyson.co.uk/store/partsDetails.asp?part=ACC-DC04CYCLONE-STD&product=DC04-SY-STD-BC
Alternatively, if you'd prefer to discuss this directly with one of our experts, or to place an order over the phone, you can call us free on 08002980298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Aug 20, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
The cantister on my DC04 no longer stays secure when in position. It does not snap and lock into place as before. I found a small plastic tab about 1/4 inch deep and less than an inch wide on the floor. ...
Check your warranty. If it's still good read to find out if this part is covered (probably not) and where to take it for repair or replacement of the tank.
Unfortunately, it may turn out you'll need to buy a new vacuum.
Nov 16, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
My Dyson DC17 Animal Bagless Upright does not click to stay in an upright position. It works but the handle falls to the floor.
This is a common fault with the Dyson DC07 (and other Dysons) unfortunately the clip that holds the handle upright hs broken. It can be repaired, but will cost a reasonable amount to have done... I would just live with the problem and prop the vacuum cleaner against a wall when not in use.
Aug 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I want to remove the power switch on a dc04 to repair a broken wore, how do i remove the switch?
Go to www.dysonmedic.com then scroll to the bottom of the page and click on DC04 cable change. You won't get better advice anywhere (and I've got no connection with dysonmedic).
Jul 18, 2009 | Vacuums
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
62 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
