Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice maker /themostat
Themostat overheats and ice melts into clumps
  • chrisbernacc Aug 03, 2008
    can anyone help me/??
  • 126 Answers
ARE YOU TALKING ABOUT THE THERMOSTAT ON THE ICE MAKER IF SO HAVE A TECH TO SERVICE AND REPAIR IT.GOODLUCK.MOHAMED
Posted on Sep 17, 2008
The ice being produced is large clumps that melt and refreeze and stop the auger from turning. I have to use a blowdryer to melt the ice just to remove the bin. Any suggestions?
Can you provide a model number of the refrigerator? Is the water filling too high in the ice maker? Are the top of the ice cubes connected together before the ice drops into the ice bin?
APPLIANCE 911
Jan 04, 2016 | Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
GE side by side refrigerator with automatic ice - ice clumping
Most likely happening during defrost. Replace defrost thermostat
Nov 17, 2017 | GE Refrigerators
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker freezes Whirlpool gold
try to remove all the ice in the bucket first and start all over again. the first bundle of ice could be the one making the problem. and then check the cold air vent towards the ice bucket. there should be cold air blowing to it to maintain the temperature in order for the ice not to melt.
after removing all the ice and inspecting if there is cool air coming out towards the ice bucket. let it run and observe it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
Clump of ice in bucket
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Jan 20, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
