Top Load Roper Washer 7 cycle 2 speed W10330949A Bought 2 months ago ..not hooked up right away either While machine is in the washing cycle...water keeps draining out and refilling. Also Water is way too cold and we have both hot water and cold water turned on. Our water heater is right next to our dryer that is right next to the washer. It is detecting water levels as it keeps siphoning water out of the tub and seems to siphon it back in constantly while it is washing and it keeps trying to adjust the water level it seems. Is it because it needs air in the drain pipe or what? Would appreciate some info on this...thanks in advance.
    Champion:
  • 239 Answers
The drain hose needs to be higher than the top of the water level and yes, there needs to be an air gap so the drain does not siphon. As far as temperature, the machine will automatically put in cold or hot water depending on the temps selected. You cannot get straight hot water from this machine...that is by design. You will have to live with the temps you are given...I know, it sucks!
Kelly
Posted on Mar 21, 2011
Washer fills with water but will start draining before washing cycle begins
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Aug 28, 2011 | Roper RAS8244KQ Top Load Washer
Water drains out instead of filling up during the wash cycle
heatman101
Oct 30, 2010 | Roper RTW4300SQ Top Load Washer
Drive link is broken
take the screws and brackets holding the motor and pump, pull it to the side and you can see where to replace the drive link
Apr 24, 2009 | Roper RAX4233PQ Top Load Washer
Washer runs through the cycles but does not drain
Hi There,
Check the water pump and belt. Let me know if this helps.
Mar 19, 2009 | Roper RAS8445KQ Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
WASHER WON´T WASH OR SPIN
Hi
Sounds like a lid switch issue to me. the washer wont run if it thinks the lid is open. its a safety mechanism. Replace the lid switch. it's a cheap try and probably the right answer
Dec 10, 2008 | GE WPGT9360EPL Top Load Washer
Washer will not spin, during rinse & I'm assuming spin cycle
throw pin in trash..shipping pin..spin problem..if motr runs and unit agitates suspect transmission or clutch on top of transmission
Nov 27, 2008 | Roper RAX4233PQ Top Load Washer
Roper Washer
Most likely to be something in the water pump but could be anything in the mechanical assembly. PLease rate my help
Oct 02, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
