Question about Dell Dimension 4600 PC Desktop
Connecting to my Monitor
I am having trouble connecting my 4600 Dimension to my monitor.... I seem to remember something about how to connect....something  to do with the video card.... some thing I need to do... but I cannot remember
  • 118 Answers
You need to screw in the monitor plug, to the socket on the back of the computer. Very simple, push onto the same sized plug and screw. Then do the same on the monitor :D Good luck
Posted on Sep 07, 2008
Dimension 4600 no display turn on. HD spins lights lite and can turn off no bios screen display
Change the VGA cable from the monitor, first but sounds like it's the video card that's failed. I would check the monitor with another computer to make sure it's not that.
Jun 03, 2014 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
How do I replace the graphic card on a dell dimension 4600 desktop
open left side of computer (after shutting it down and disconnecting it)locate the graphics card, its the one your monitor connect to,disconnect monitor cable from board remove little screw holding card to back frame and ease card out replace with new one put it all back together and start pc up if it asks give it the software disk that comes with new card and follow the instructions.
Jul 06, 2010 | Dell Dimension 4600 Video Card (M9 TVT...
Will an Acer AL1716 monitor work with a Dell 4600? Do I need a monitor card?
http://reviews.cnet.com/desktops/dell-dimension-4600-for/1707-3118_7-30529709.html
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Acer AL1716 17" LCD Monitor
Extended Desktop on Dell Dimensions 4600
yes your right..leave it set to AUTO BUT ONLY USE THE ATI CHIP SET VIDEO CARDS.
Dell Dimension 4600 We saw great image quality from the 17-inch E171FP analog LCD monitor that accompanied our review system. Text looked sharp and evenly focused at all sizes, while colors appeared lifelike, with evenly saturated tones in our photo test screen, in a DVD movie, and during a session of Return to Castle Wolfenstein. As part of a new case design for Dell's midrange Dimension line, the 4600 has eight USB 2.0 ports, more than on most value (and some power) systems: six on the back and two up front. An audio port for connecting headphones sits next to the front USB ports.
The compact 4600 does not have the tool-less accessibility of its predecessor, the Dimension 4500, although opening the case is easy: Just depress a thick L-shaped lever and lift off the side panel. You'll need a screwdriver to add a PCI card or a hard drive; unlike the 4500 series, which secured expansion cards and drives with innovative quick-release mechanisms, the 4600 series uses screws. Our test configuration had only one available drive bay (a vertically mounted internal bay), and it's a struggle to use it. You must remove four screws (two on the bottom of the case and two inside) and take out the bay holding the existing hard drive along with the empty bay that's crammed up against the front of the case. The two open PCI slots are reasonably easy to access, but to reach the two open memory sockets, you must push aside a snarl of data and power cables.
The Dimension 4600 we tested came with a 2.8-GHz Pentium 4 processor and 512MB of DDR400 memory. It earned a PC WorldBench 4 score of 122, about average for similarly configured systems. The ATI Radeon 9000 Pro graphics card is not a top-of-the-line board, but it yielded solid frame rates in our gaming tests. And it's perfectly fine for playing games at moderate resolution, especially considering that the bundled LCD monitor won't display anything higher than 1280-by-1024 resolution. It has a combination DVI/analog-out port (you use an adapter to hook up an analog monitor), plus S-Video-out and composite-out ports to output video to a TV.
Please leave comment and feeb back.
Thanks
Feb 24, 2010 | Dell Dimension 4600 PC Desktop
Cannot install 17 inch monitor on dell dimension 4600
You have not installed your graphics card drivers! ----------
The drivers are here ---> Since I dont know which graphics card you have you will have to try each one... dont worry if the driver dosent find your card it wont install.
Do you know the full model number of your system , it is printed next to the serial number if you give me this number I can link you directly to the driver -----------
Jan 24, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
Blank moitor
can you chk anything abt the lights on the monitor ? ie.. the small ones near the power switch .. is it green / orange ..
Also do u hear any beeps when you power on your computer ? I vaguely remember that in case you hear three beeps, it could be a video card issue.
- Ranjit
Nov 08, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
75 people viewed this question
Alun Cox
