Question about D-Link DIR-600 Router
Iam having different ips from wan is this mean someone is accessing my network?
  • 93 Answers
You just have Dynamic ip, nothing to worry about.
"Static IP addressing is for one customer on one IP address and Dynamic IP addressing assigns a different IP address each time the ISP customer logs on to their computer, but this is dependent upon the Internet Service Provider (ISP) because some ISP's only change the IP address as they deem it necessary.
If you have Dynamic IP Addressing through your Website Host it means that you are sharing an IP Address with several other customers.
If you are a beginner on the internet, an avid internet user, are entertaining the thought of starting your own website business, are a gamer, use VOIP or VPN there are several things you should know about IP Addressing."
Read more
Posted on Mar 21, 2011
    Novelist:
  • 66 Answers
I take your question as this: You are noticing that your IP address of your router is changing and are concerned that it means other people are getting on it.
The WAN port can change IPs based on disconnects from your internet service provider and unless you pay for or have an agreement to get the same IP from your ISP everytime, this is very normal and does not, by itself, indicate that someone else is accessing your internal network.
However, if it's your internal IP address changing it could be an indication that someone else could be connecting to your wireless connection. The way to prevent this is to ensure that you have WPA (or WPA2) security enabled on your wireless router. You can refer to the manual (http://files.dlink.com.au/Products/DIR-600/Manuals/DIR-600_B1_Manual_v2.01.pdf) on how to enable this security.
Hope this helps!
I have a speedport W722V router with several computers conected using wireless network. A have also an Asus WL 600g router that I would like to use as an AP to enable me to use the USB printer port to...
configure the 600G to a static IP on the same subnet as the 722, and then wire it port to port (say, port 1 to port 1, do NOT use the WAN port) - don't forget to disable the NAT/DHCP on the 600G after you assign it's network IP address (not the WAN address, local address, the WAN port will no longer matter and will be unused on the 600G)
May 09, 2011 | ASUS WL-600g Wireless Router
No internet access with wireless
First of all check the DSL cable must be in WAN port of the linksys router. if it is done then do the following.
Actually DSL modem and Linksys router are conflicting with their IP class. Means DSL and Linksys routers are using the same IP class of 192.168.1.1 or 192.168.0.1.
You must change one's IP class because both are routers and if they having same class they cant communicate. Unplug the WAN cable of the linksys. open browser and put ip 192.168.1.1 or 192.168.0.1 any one which works for u in the address bar. Username and password hopefully be admin admin or just admin and password blank field.
when you access the linksys router configuration page then come to LAN configuration. If there IP is 192.168.1.1 then change it to 192.168.0.1 and if it is 192.168.0.1 then change it to 192.168.1.1 Save configuration and reboot your laptop and plug dsl cable to linksys WAN port.
Hope now this will work.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion dv6000z Notebook
How to configure my tcp/ip TP-link access point
The router has both a "WAN" (Wide Area Network) side
and a "LAN" (Local Area Network) side.
On the WAN side, most ISPs (Internet Service Providers) will provide the values for IP-address, subnet-mask, and gateway.
On the LAN side, you should just use the "default" values.
Connect your computer via an Ethernet-cable to the router,
and the router will supply values to your computer,
so that your computer can communicate with the router.
Nov 06, 2009 | Computers & Internet
Cant get my router to work
Connect the computer to LAN port one of the router using an Ethernet cable, access the configuration page (ie 192.168.1.254), configure the router as Dynamic IP, Configure the wireless network as (WEP or WPA), Check the IP address of the WAN section.
Note: If you have an IP address to the WAN section the Internet connection is working, Connect through the wireless network by finding the wireless network name was been created to the router.
Mar 09, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Iam having an issue with the dlink router , getting 0.0.0.0 ip address for wan
Hi, first establish that the wires are plugged in to the correct ports, WAN port on the back of the router is in the internet port on the ADSL (assuming that is what your using).reboot the ADSL modem and wait for the light to settle, the link light should be solid. The ethernet light does not need to be solid, and the Act or activity light should be blinking, Now go to the command prompt and type in
> ipconfig /all. you should get a WAN ip. Otherwise, check if your service provider needs the MAC address of the router to establish it on the network...Telus used to need this. If this does not work, take the wire from your computer and plug it in directly to the back of the modem, this should get an WAN IP so you know that the router may need a bit of tweeking and a reboot of the hardware may be in order to sync everthing up again,,goodluck
Jan 06, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Router no connecting to the internet
You need to configure NAT on the router to permit the entire LAN to access internet
Example.
LAN Segnment is 192.168.1.0/24
1. Create an access-list to identify the local segment
2. Configure the Nat interfaces properly (NAT-INSIDE, NAT-OUTSIDE)
3. do the NAT configuration
i.e ip nat inside source list (ACLNUMBER) .....
Dec 08, 2008 | Computers & Internet
Difrence of lan wan
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Jul 10, 2008 | Computers & Internet
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Two routers US robotics connected together
It appears you may have confused the world because of your IP addressing choices. Do you know what a subnet mask is? It determines which machines share the same network with other machines. Routers by design are the connection between different subnets, Most routers default to 255.255.255.0 for the subnet mask which means both of your routers are in the same subnet as they are 192.168.2.? meaning you have two separate networks sharing the same same subnet address when they should be unique. Try making the wireless router 192.168.3.3 or 192.168.3.1. This puts devices in your wireless network on the 192.168.3 subnet and the devices in the ADSL subnet in the 192.168.2 subnet which includes the WAN half of the wireless router. I believe this will correct your network issues. In this case if hardcoded the gateway for the wireless router would be 192.168.2.1 also known as the the adsl modem
Dec 02, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
D-Link DIR-600 Router Logo
452 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
