Question about Watches
Need to change battery in EH23sa - Watches
The battery is actually accessed from the front of the watch.
You should have a "Case Knife" to remove the front bezel.
Remove the band first.
Set the watch in its side. Set the case knife at the groove where the watch band holder meets the front bezel, and give the back of the knife a sharp rap with a small hammer. The front bezel should pop off.
Some watches have a small circular plastic piece that will also come out. Gently remove the movement from the front. The battery (CR 2025) can then be removed from the back of the movement using a small, thin blade. Install the new battery. The inside back of the case should have restart instructions. (Push A -left button once. then push and hold A until hands move to 12:00. Push B once to start reception.
The back of the watch is plastic. Don't try to remove it.
Gently re-assemble movemengt. A watch case press tool is best for finishing assembly. I would suggest taking the watch to a jeweler if you are uncomfortable taking this watch apart. Good luck
Posted on Nov 24, 2013
How do I set time on an eh-23sa watch
http://www.lacrossetechnology.com/eh23sa/manual.pdf Hi Bill click link this will explain in detail your question i think you will find it is automatic and sets itself ..but check instructions will tell you hope this helps
Dec 23, 2014 | La Crosse Technology E. Howard Ambassador...
Tip
E.HOWARD&Co atomic watch manual.
Follow this link and get E.Howard&Co atomic watch manual/instructions: http://www.ccrane.com/instruction-manuals/e-howard-and-co-atomic-watch-eh23sa.pdf
on Feb 18, 2010 | Watches
What battery does the fossil fs 3105 watch take
It's actually a lot easier than that video shows. You're trying to represent a watch that is a PDA! To change the battery in your watch, you need to purchase a watch kit on eBay for about $15-$25, purchase the correct battery, watch a realistic video of changing a battery on Youtube, and then you will never need to pay more than the cost of a battery (a few dollars) to change your watch battery ever again! Sending it to Fossil takes time and money and you can do it at home with basic skills!
Jan 16, 2011 | Fossil FS3105 Wrist Watch
I had my battery changed, but the hands are not working. Do I need to wind it?
did you change the battery yourself ? You might have to resett he watch to have it started up . You only need to wind automatic watches. So no you do not have to wind your watch. It could be a bad movement
Oct 18, 2010 | Watches
I just replaced the battery on a fossil watch and it won't work. How to you reset it? or what else needs to be done? Please help me. thanks.
mcdevito75 here, Your Fossil watch should work with the battery change, of course it will need to be re-set. You"ll have to double check the battery install, make sure the battery contacts are clean, use a piece of paper towel and carefully clean the battery contacts. Hopefully your new battery is not dead. Another thing to check for, is that the buttons contacts are lined up with the quartz movement. While you double check your battery install, carefully press 1 button at a time, and make sure each button is making contact with the quartz mechanism, many times during a battery change to quartz movement may move just slightly but enough to keep the buttons from contacting the movement, this will keep the watch from working. Hopefully 1 or all of these is the answer for your Fossil watch.
Aug 22, 2010 | Watches
I have a oakley watch, which i need the battery replaced who would do that for me, becuase i heard it need to be sealed propely?
If ANY watch is rated as water-resistant, then that guarantee of water-resistance is void once the back has been removed for a battery change. You will need to take the watch to an Oakley approved dealer for the battery change, or to any reputable jewellers/watchmakers/watch repair shop that will test the watch for you after the battery change. Testing is done 'dry' so there's no danger of water entering the watch.
Aug 01, 2010 | Watches
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
129 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
