Question about Dell OptiPlex SX270 PC Desktop
I had a dell sx270, i can't power it on when i plugged the power supply and only green light led is light on in the mother board. can you please advised me what will i do? is it related to to board problem.. please advised. thanks in advance
    Master:
  • 525 Answers
Ive seen this before and it usually means you have a dead motherboard.
Posted on Mar 22, 2011
Flashing green light on the circuit board. No power at all
I suggest it is the mother board or the power supply. Go to the Dell website on a friend's PC and download PDF manuals pertaining to your model. The battery may have enough power to light an LED.
Jan 08, 2014 | Dell Dimension XPS PC Desktop
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
Optiplex SX270 LED light code
Hello
The LED code you described indicates a memory failure. Remove and re-install all of your memory. If this does not fix the issue, remove all memory and insert one stick at a time until the unit turns on. Replace faulty memory.
Here is the LED Code guide from Dell...
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408
May 01, 2010 | Dell OptiPlex SX270 PC Desktop
My sx270 wont power up
Known issue, bad capacitors.
http://www.badcaps.net/forum/showthread.php?t=2607
Examine the motherboard, if you see the bulging capacitors strip it for
parts (RAM, hard drive), trash the unit and buy a new computer.
Dec 29, 2009 | Dell OptiPlex SX270 PC Desktop
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
PC won't 4power on.
Failures in the motherboard, memory, or any installed card could cause that symptom. All I can suggest based on the above information is remove memory one piece at a time and retest, remove/reseat video card if you have one, and attempt to reset the CMOS using the jumper on the board. You might also try removing the battery on the board and unplugging everything, then attempt to reboot.
Jan 03, 2009 | Acer Aspire™ T180 PC Desktop
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
My computer will not power on
brand and model of the computer would be good.... as well there is a switch on the back of the computer on the power supply. toggle it to the other position and try again
Robert
Sep 08, 2008 | Dell OptiPlex SX270 PC Desktop
TO noggin
remove all pwoer connector from motherboard and short green and black wire in supply shocket.If supply is run then it is the problem of motherboard.
Feb 28, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
No power no light
Could be either one, or it could be the toggle switch.
Start with the easiest first to check. Unplug the power toggle switch from the mainboard and take a screwdriver or something and short out those two pins to see if it starts the pc. if it does, then your pc case switch is just bad.
If that's not the problem, check the power supply next.
Jumper the ATX 20 pin power cable's green wire to any black, just to make sure the power supply is working. The fans in the power supply will turn on along with anything else hooked up.
To jumper the power supply use a section of wire or a bread twisty (with the insulation removed from the ends) and just connect the green wire to any black wire on the 20 / 24 pin power connector. Make sure that the power switch on the back of the power supply is switched on.
If neither of those seem to be the problem, then most likely it is the motherboard or the processor.
Dec 21, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell OptiPlex SX270 PC Desktop Logo
265 people viewed this question
Alun Cox
