Question about GPS
The ceiling lights are not working but lights above bed do
  • 5,370 Answers
What is the brand of the product, what is model number.How old it is.please give more details for exact troubleshooting and help.Keep updated.Helpmech.
Posted on Mar 21, 2011
I have two minka aire ceiling fans in the m bed rm, controlled by two separate wall remotes which are hard wired and have dip stwitches on there back sides, one fan/light works and the other will n
I think you have a mixed or a connected wire problem. It looks like your breaker has tripped, doesn't need to spark... :) to trip. Is everything the same voltage ? Are you sure there's power at the switch mentioned..
Don't take anything for granted, respect electricity..
Jan 27, 2013 | Minka Aire Ceiling Fan
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
Daughter was shaking out her bed sheet when it hit the ceiling fan and all the lights went out, looks shorted. Do I need to buy a new light unit?
no, you don't need to buy another unit as long as your ceiling fan motor still in good condition. most probably the cause of the blackout is the overload of the fan motor when the fan blades entangled with the sheets and it trips the breaker due to over current.
if your fan still runs by now then it is ok. to be sure, have it checked for a qualified person.
Dec 29, 2010 | Hampton Bay 24002 Ceiling Fan
Fan is wobbling and noisy--cannot figure how to tighten the light fixture part of fan
I have a number of ceiling fans and its usally wise to just check that each blade as all the washes and fixing. As leaving just a washer out can alter the whight and balance.Some noise is to be exspected till they bed in so to speak unless they wobble really bad
Sep 29, 2010 | Hampton Bay 24002 Ceiling Fan
I need assembly instructions for disney princess
Use the hardware that comes with the Disney Princess canopy package to install the main canopy hook in your ceiling. Center the steel ceiling hook above the center of the twin bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions and insert the four poles into the sleeves of the canopy. The two longer poles will run lengthwise above the bed, while the two shorter pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling hook by slipping the plastic ring of the canopy onto the hook. The four polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
  • Jul 10, 2010 | Princess International Nursery Crib Bed...
    New Hampton Bay Ceiling fan - runs only in clockwise direction
    By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
    Jan 17, 2009 | Hampton Bay 24002 Ceiling Fan
    GPS Logo
    13 people viewed this question
    Top GPS Experts
    Marvin
    Marvin
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
