Question about GPS
I need a pinout for the bosch 1267632013 map sensor thats in my bosch mp3.2 ecu from my peugeot 306 s16,there are 3 pins and i need toi know whats what
starlet4life
  • 89 Answers
SOURCE: peugeot 306 3025 radio has no codes
http://www.sws-solutions.co.uk/radio_coverage_blaupunkt.php
Posted on Sep 27, 2008
  • 142 Answers
SOURCE: ECU pinout?
www.suzukiinfo.com has heaps of diagrams. Should be one there to help.
Posted on Jan 03, 2009
  • 37 Answers
SOURCE: pinout ecu toyota 22re 1989 p/up
this should do the trick
http://media.photobucket.com/image/1989%20toyota%20pickup%20ecu%20pinout/4runnerchevy/other%20conversion%20stuff/ecupinoutdiagram.jpg
Posted on Apr 22, 2009
  • 279 Answers
SOURCE: Peugeot 306 blower not working
have a look at the wiring to the reostat and heater motor they are known to burn out at the plug connectors. also mebe sure the motor has not siezed
Posted on Dec 07, 2009
SOURCE: peugeot 306 Radio Code,
does any one no what the radio code is for my peogeout 306 maridian
Posted on Jan 07, 2010
I have a 2000 GMC Jimmy, I need to know where the sensor ground points are out of ecu
2000 blazer ecu pinout3-khpbmhaocwhdo3b0pqdplrqt-5-14.jpg Connector 3 32 pins (Clear) pin 16 and pin 17
Have a looks at ECU pinout chart
Hope it helps.
Apr 12, 2018 | GMC Cars & Trucks
Ecu pin out 2mz-fe auto...toyota windom...
[PDF]WIRING DIAGRAM BY MODEL - Apexi
www.apexi-usa.com/manuals/electronics/neo_diagram.pdf
TOYOTA. Table of Applicable Models. ..... The orientation of the ECU depends on the vehicle with ECU pins. Install the ECU fully checking the .... 2MZ?FE. '97.5?'02.1. VEROSSA. JZX110. 1JZ?GTE. '01.8?'04.4. L. T10?b. HW?23.
1997 Camry V6 ECU Pinout - Toyota Nation Forum : Toyota Car and ...
www.toyotanation.com/.../97568-1997-camry-v6-ecu-pinout.html
Sep 19, 2005 - 10 posts - ‎3 authors
So as the title says, Anyone know the pinout to help with a SAFC install? ... look in the apexi install manual, it is t8-f. the same as the 2mz-fe ... Perkins 99 Camry 1mz Build
Nov 28, 2012
1mz-fe to 2mz-fe
Feb 25, 2010
SAFC Wiring Pin-Out for 94 1MZ-FE - Toyota Nation ...
Feb 8, 2008
1996 1mz ecu pinout needed and question
Feb 18, 2006
More results from www.toyotanation.com
Dec 03, 2015 | Cars & Trucks
NEED PINOUT ON LTC 0828/25C CAMERA HAVE NO PLUGS and wiring diagram
try service manual, manualslib.com may have what you need.
Mar 22, 2015 | Bosch Dishwashers
I am thinking of buying an OBD2 tool to read and write engine mapping from Peugeot and Citroen cars with EDC16. And my friend recommended me you to me. So I am wondering if you can recommend me a device to...
We do not have a tool that especially designed to read and write engine mapping with Peugeot and Citroen cars. But we have two device that can do this. They are KTAG ECU programming tool and KESS V2 ECU tuning kit.
KTAG K-TAG is designed to meet our customers need and is known as inexpensive but reliable. It is compatiable with dozens of auto protocols, including SKODA BOSCH EDC16, CBMW BOSCH EDC16, PEUGEOT BOSCH EDC16 and CITROEN BOSCH EDC16C.
Different from KTAG, KESS V2 is a professional oriented tool. It supports all major brands and protocols you can find, including that for Peugeot and Citroen. As a professional tool, it supports more functions and languages than KTAG, and is of course more expensive than KTAG.
You can try one of them according to your need.
Apr 14, 2014 | Cars & Trucks
2006 chrysler pacifica diagram of map sensor
on all cars, (in general,) the map can be only for EGR
or for FUELING. (the latter is called the SPEED Density System)
is this a USA car, and not Canada. (i dont do the market thing that is your job to tell me,or open hood and show me...)
MAP the out side diagram or the inside,
it is just an barometic sensor. some cars have 3 of them.
one for altitude , that you have yet to discover.
my guess ? i can t there are 3 engines. 3.5/3.8/4.0 liter
ill take a wild guess and land on 3.5L
the online fSM shows 21 diffr. (ign/fuel) systems.
the first 3.5l does use a 3 pin map and is the SDS, (map controls the AFR, there is no MAF air meter on car)
pin 1 is map signal out
pin 2 ECU quite ground.
pin 2 is 5vdc , refer. supply from ECU, also used for EGR feed back power at the EGR solenoid.
is that what you need?
the output is 0v-4v or tad more
and is an non linear function, that looks like the below.
your FSM will have batter facts.
this MAP is absolute type, that is it reads max.
under the full pressure of the atmosphere at sea level
or about 14.7 PSI.
here is a rev, engineered map as a guide, diff, car.
but works just the same way
http://www.fixkick.com/sensors/my-map.html
Oct 10, 2013 | Cars & Trucks
I am replaceing my existing o2 sensor with a bosch oe smartlink universal sensor. the existing wires are brown/yellow, gray, pink/black. and green. how do I wire the new sensor to the old wires?
you need the factory color code and the bosch color codes.
then wire per that. there is no other way. (universal)
that is the penalty for not using a PNP sensors, plug and play.
do not mess up,wiring the 1 heater to the CELL + wire
risks blowing out the senor or ECU. a $500 error.
here a list. 89-98 list.
first the bosch list ,with comments. my 91 , just and example.
http://www.fixkick.com/oxy-sensor/bosch-pinout.JPG
all bosch unversals sensors have a paper inside,
and is very hard to read and understand.
my guess is it fails german translations.....
no biggy
your car is a 4 wire sensor.
on my cars 96 , the heater wires are non polar so are much easier. lets do them first.
the bosch color is.white, on my car its blk.
so i wired, bosch white to my cars black. x2
bosch gray is sensor ground, (special) wired to cars white wire.
every year, suzuki changes wire colors, not reading the FSM is FAIL.
and last my Bosch CELL+ pin is black and wires to my cars blue.
O2 are like battery CELLS, and are Polar.
Suzuki changed the blue color like a drunk sailor spends money.
a royal PITA. that is. LOL !
the for sure solution is to look it up in the FSM.
for all wire, find your blue, and win !
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
see the 9 times suzuki changes here, prior to 2004
http://www.fixkick.com/sensors/OxyGen_sensor_help.html
did they change in 2006, ? Ill never know, as Suzuki is bust here.
nor will i pop for $15 to find out. When my Suz, dies, that be the end.
btw 2: the sensor colors on any suzuki are "NCA". FSM drawings.
no color assigned.
the colors mentioned are HARNESS colors in the sensor side.
suzuki uses many different brands sensors and colors, or reserves the right to do so at anytime. Bosch, NGK, Delphi, etc.
tricky huh? thus the pages , linked.
back in 1996 they should have set ISO standards but did not....
i hope that is not confusing.
but in a nut shell.
1: grab bosch sheet,
2: grab the car schematic, for ECU. (fsm, or alldata, or mitchells)
there is your answer.
no man as the blue wire color on all car or all suzuki;'s
not yet. tell my yours and ill update my records.
Aug 17, 2013 | 2006 Suzuki Forenza
What pins on the ECU wire harnes does the ECU use on a 2001 Dodge Grand Caravan Sport
The vacuum line on top of the EGR is required for propper vehicle operation. The vacuum line is what opens the valve when the solenoid is comanded on. As for the MAP sensor check the injector/MAP sensor harness right by the driver side corner of the rear head. The harness tends to melt and cause rough running conditions and misfires. So would the EGR which is a common issue and yes the the whole assembly should be replaced.
Jul 01, 2012 | 2001 Dodge Grand Caravan
Peugeot 306 cant get any spark at the plugs fitted a new ecu still not working! Any solution's please ?
Have you been through deep water? the coil packs are prone to water damage.
Feb 17, 2010 | 1991 Peugeot 405
GPS Logo
280 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
