Question about Canon Office Equipment & Supplies
Canon MP510 does not print black, has new print head & new black ink cartridge, deep clean does not help, colors are OK. Initially it was intermittent black print. Now, no black at all.
  • 1,218 Answers
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Posted on Mar 22, 2011
Need to print only black ink on canon mp510
in the printer set up ( normally in the print section , change the color to black and white , make default and ok
Jan 11, 2012 | Canon PIXMA MP510 All-In-One InkJet...
My Printer prints a Colored Ink. But I type as a black Font Color.Then Black Ink Has full?? pls help me
Hi Carl Montero,
Your issue may be attributed to two possible points of failure. 1.) The Nozzle is clogged, 2.) the ink is already dry inside. You can try to clean the nozzle by doing the following steps. If it does not work, try to replace the cartridge with a new one.
FINE Cartridge Cleaning
1 Press [Menu] repeatedly until appears. 2 Use [ ] or [ ] to select . 3 Press [OK]. 1 Press [Maintenance] repeatedly until appears. 2 Press [Black] or [Color].
FINE Cartridge Deep Cleaning
Note If deep FINE Cartridge cleaning does not improve the print quality, contact a Canon service representative.
Jul 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision roller.com.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
Wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Dec 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
CANON S9000 won't print in black
Here's what just fixed mine... I was having the same issue...
Mac:
Go to System Preferences
Open Print & Fax
Select your printer and open Print Queue
Click Utility
Select your printer & click Maintenance
Select the "Deep Cleaning"
That worked for my black ink!
Aug 09, 2008 | Office Equipment & Supplies
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
359 people viewed this question
old marine
old marine
