I get a norton warning that I have high cpu usage yet Im not running any programs.My computer is running slow and doing alot of clicking noises.I have 98% available free space on my hard drive and i recently defragmented it but that didnt help
    Novelist:
  • 107 Answers
1. Try disabling some of the Startup Programs.Press the "Windows" key on your keyboard and the "R" key at the same time. When the run dialog box comes up, type "msconfig" then press OK. The System Configuration Utility will open. Go to "Startup" tab, disable all startup programs, hit OK then restart computer.
2. Test if the computer still runs slow, if it doesn't try repeating the step 1, and re-enable the startup programs one by one or you can just check on the programs that you want to automatically start whenever you start Windows. These startup programs eats your computer resources which should have been used by the computer for processing instead.
3. If you hear clicking noises from the computer it might be the computer's Hard Drive. Download and run a Hard Disk test. You can download Hard Drive Utilities from here - click this link
4. If the Hard Drive test fails then we will need to replace the Hard drive. If it passes run a full system scan using your Security software. The computer might be infected by a virus/malware which causes slow performance.
Hope this helps.
Posted on Mar 21, 2011
    Scholar:
  • 58 Answers
High CPU usage is caused by many programs trying to process data at the same time. It is based on programs that are running, not how much data is stored on the Hard Drive. Press "Ctrl + Alt + Delete" to bring up task manager. Go the the 'performance' tab at the top of the screen. This will tell you what percentage of the CPU is being used at the time. If you go to the 'processes' tab, you will have a list of everything that your computer is running. The 'CPU' column will be 00 for many processes. Any process that is not at 00 is using your CPU. Look for processes with a high CPU number. If the 'User Name' column matches your name, you can select the process and click 'End Process' in the bottom right to kill the process. Norton itself tends to take up a lot of CPU, and depending on how old your computer is, you may need to use a different malware solution.
What does high CPU usage mean?
Most times the hard drive is full, delete any thing you don't want ,to free up space . increase ram to four GB if you can. Get rid of add-ons Run a anti virus programe.
Mar 06, 2015 | Computers & Internet
My dell is too slow even if i am playing computer games. why?
Your Dell laptop has low RAM/high CPU usage, a lot of games tend to use high CPU, so your laptop could be a little old for newer games, so you should upgrade it, or you have a lot of files on your laptop and maybe you opened to much high CPU usage programs.
Sep 10, 2013 | Computers & Internet
Slow running of window vista
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | HP Pavilion dv9000z Notebook
My laptop is operating very slowly!I dont understand the problem!
1. First of all download and install CCleaner, it is free.
Here is the link http://www.filehippo.com/download_ccleaner/download/1d59b13e3d0824a0c054077615cab5c3/
2. Run the exe and then follow the instruction to install the ccleaner.
3. After opening the ccleaner, select all the check boxes inside the cleaner tab.
4. Click on Run Cleaner.
5. Click on Registry in the left side tab.
6. Click on scan for issues, then click on fix selected issues. Click on no when asked to back up.
7. Go to Tools Tab and then click on startup tab, Now uncheck all unnecessary and unknown application from being startup.
8. Restart ur computer.
Check now the performance.
If you think there is any virus in your pc, then scan your pc with ESET NOD32 On demand scanner or install Quick Heal. If you want free antivirus then download and install avast home edition 5.0 and register for 1 year free license. (WWW.AVAST.COM)
** After doing all this, if u further want to improve ur system performance then tell me the Operating System installed in your system then I will tell you how to improve.
Jan 31, 2011 | Computers & Internet
Hi im running windows vista home premium, and ive noticed my fan has been running all the time for months now and it gets really hot, I also noticed that my processor runs between 60 & 100% now too. im...
With all the stuff running in the background of Vista, and Norton, you could very well be maxing out the computer. Memory, processor or both. I have a laptop, and I close down the HP total care advisor, and any periphial programs running that I am not going to use. like backup programs and printer standby stuff. Norton does use a lot of resources especially on updating an d processing the updates. I usually let my PC do it's thing until the HD activity light quiets down before I try to use it.
May 28, 2010 | HP Computers & Internet
Pc working slow. i have done disk clean up deleted temp files .scanned pc with 3 antivirus but none detected any threat .i have 1 gb ram and 80% free hard disk space.i have downloaded ccleaner and fixed...
Dear Sir,
go to hyttp://xviruslab.blogspot.com and go to System Utilities find PC Booster download and install and run a auto run it will clear all your problems
bye bye
keerthy
Sep 29, 2009 | Computers & Internet
Slow startup slow all together
The first thing I'd try to do is see what programs are running at startup. To do this Click on Start--> Run -->type "msconfig" without the quotes.
Click on the Startup Tab and view all the programs that are running at startup. As for deselecting which programs run at startup you can directly ask me which ones you can disable. For the most part all instant messengers and most program files can be disabled.
DO NOT disable any Windows/system32 files!
Jan 19, 2009 | IBM ThinkPad T30 2366 Notebook
CPU usage very high, mouse very slow man
hi,
you haven't mentioned whether your mouse started moving after you deleted the applications..
Anyway to lower your CPU usage, you can do the following...
1. Run 'msconfig' without the inverted comas in the run dialog box. ( start--> run )
2. Select the startup tab... you can disable all application at startup to load the system faster. or you can select the application that you thing is unnecessary. this needs a restart.
3. Next try to press Ctrl, Alt , Del at the ssame time to launch the task manager. First you will be seeing the application that is running. Go to the next tab that is the Processes tab. under this you will see all the processes that is running and utilsing how much resources . Below on the status bar of that window you will see the cpu usage... Now identify the processes that has the highest memory usage... right click and select end process tree. the process will be stopped. Remember not to end the explorer.exe process. Most resources is utilised by Anti-virus softwares like norton, also by web-browsing and graphics opertaions....
hope to get rated as fixya!!
regards
bzoy..
Jan 03, 2008 | Acer Aspire 3000 Notebook
Laptop computer lagging horribly
You have something running in the background that is eating up the CPU useage. You need to identify which process is doing this.
Use the built in task manager, using ctrl-alt-delete to bring it up, and see which process is at above 90% cpu usage. Then post back here what you find.
Oct 23, 2007 | Acer Aspire 5100-3357 Notebook
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
