Question about Acer Aspire One Netbook 8.9" Notebook
When starting up the netbook, it begins to load Windows xp - then recommends doing a disk check - when it begins to do the disk check, it shows "File record segment 1420 is unreadable." and does not continue. Can you offer any assistance ?
  • 72 Answers
You Hard drive is damaged you need to get it replaced. Try to get the warranty done on it.
Posted on Mar 21, 2011
How do i fix a hard drive over load or a virus on my acer netbook?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 30, 2012 | Computers & Internet
Am trying to reinstall window xp on lg x130 but its unable to load windows bringing an error
Wow, chalk one more up for me and my advice to never buy a netbook, tablet or anything that does not have a CD Drive because one day the thing is going to crash and leave you up the creek without a paddle.
It sounds like you have some setting in the bios that is killing your windows install. If it recognized your drive from the beginning of the install and allowed you to select the drive to install windows, then you have a disk controller issue or a bios setting that is killing you. Also the motherboard could be crapping on you. I've seen it act in this manner when it is bad.
Check your Bios or System Setup and see if you have some type of setting for Large Drive Support and also check for some setting for AHCI. Change the setting (especially for AHCI) and see if it works.
Apr 18, 2012 | Computers & Internet
Its an asus pc 1018series need to re boot how can i perform it
Your asus netbook should have come with a White restore dvd. You will need an external dvd drive to use it.
Just put it in and it will boot to the disk and begin the restore process. Follow the instructions and you should do fine.
If it didn't come with a restore disk, You can Load XP or windows 7 from new media. Every driver you will need is provided at asus' website. You will need to load the xp version of the touchpad utility, as well as the chipset and acpi drivers, even if you choose to load windows 7.
I'm using I Eee PC 1000HE with 2 gig of ram and a single core Intel Atom n280 processor, and it runs windows 7 just fine. If you need more help, reply, and I will help as muh as I can.
May 09, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I pressed f10 lots of times and my internet just stopped working ,i wanto reset my klaptop to factory settings please can u help
All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
1. have the netbook connected to its AC adapter which is plugged into AC power line
2. power on the netbook and watch the screen as it starts up
3. when the acer logo is showing, hold down the Alt key and press F10 repeatedly
4. until screen indicates Acer eRecovery is loading
5. once eRecovery is loaded, follow the directions given on the screen
May 08, 2011 | Acer Aspire One PC Notebook
I have a acer netbook.when i press standby or close the lid then it become go to sleep mode but problem is creating when press enter button then i cannot start any program or it go to hang position. my...
If your windows xp is not genuine, it likely has been corrupted. This would also explain why you cannot start any program. All Acer netbooks have a factory install image on a hidden partition of the hard disk. Suggest you should re-install the original windows xp factory image. All user data on the C: drive will be cleared by Acer eRecovery which you would start up as follows....
May 08, 2011 | Acer Aspire 5315 Notebook
Hi, my acer aspire one netbook can't open XP and it says netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can...
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Apr 10, 2011 | Acer Computers & Internet
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
When i turn on the netbook computer it shows which step do you wont to do start normally safe mode all those ones when i click on one it shows the windows xp loading for a second then it flashes the blue...
Your boot files or windows installation is corrupt.
You may need a windows disc of the same version installed to fix it, if you dont have 1, or a recovery disk, you may be left with no option but to reinstall windows (You may need to buy 1)
Jul 20, 2010 | Computers & Internet
Brand new acer aspire won't load windows xp
If you can still get into the BIOS, see if you have an option for D2D recovery. if so, make sure it is enabled.
restart the system and hold down Alt+f10. if your recovery partition is still intact, this should start a factory reload of your system.
Feb 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
NEW ACER ONE NETBOOK WILL NOT BOOT UP
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Dec 26, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
