Question about Brother MFC 420CN All-In-One InkJet Printer
Black cartridge doesn't print
I have a Brother MFC-465cn and I recently changed the black cartridge (LC-51) and when I printed the test page everything printed except black, I opened another new cartridge just in case and same thing happened. After numerous cleaning and print test I gave up..
Please if you know how I could solve this I would appreciate it.
Thanks in advance,
Jay
  • 3 more comments
  • Anonymous Aug 03, 2008
    I've changed my black twice. Won't print either
  • jaygui Aug 04, 2008
    Thanks for the quick response. Unfortunately I can't find the user's manual.
  • jaygui Aug 07, 2008
    still not working after updating the firmware. Any other solution??? Thanks again, Jay
  • Andy Aug 07, 2013
    Have the same problem, the printhead itself if f*cked, might as well buy a new one. It won't be a brother!
  • Anonymous Mar 29, 2014
    have tried reseating cartridges and power off and on. no joy
  • 659 Answers
You need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Posted on Aug 03, 2008
  • Wesley Gardner
    Wesley Gardner Aug 04, 2008
    ok the following below was taken from the manual of the MFC unit which you can view all the documentation on it here
    I searched around and could not find the hard reset procedure on their website so I will have to try myself to see if I can do it on mine.
    but please read the following.
    your output, some of the nozzles may be
    clogged. You can check this by printing the
    Print Quality Check Sheet and looking at the
    nozzle check pattern.
    a Press Ink.
    b Press a or b to choose Test Print.
    Press OK.
    c Press a or b to choose
    Print Quality.
    Press OK.
    d Press Color Start.
    The machine begins printing the Print
    Quality Check Sheet.
    e Check the quality of the four color blocks
    on the sheet.
    f The LCD asks you if the print quality is
    OK.
    Do one of the following:
    􀂄 If all lines are clear and visible, press
    (Yes) to finish the Print Quality
    check.
    Go to step j.
    􀂄 If you can see missing short lines as
    shown below, press 2 to choose No.
    g The LCD asks you if the print quality is
    OK for black and three colors.
    Press 1 (Yes) or 2 (No).
    h The LCD asks you if you want to start
    cleaning.
    Press 1 (Yes).
    The machine starts cleaning the print
    head.
    i After cleaning is finished, press
    Color Start
    The machine starts printing the Print
    Quality Check Sheet again and then
    return to step e.
    j Press Stop/Exit.
    If you repeat this procedure at least five
    times and the print quality is still poor,
    replace the ink cartridge for the clogged
    color.
    After replacing the ink cartridge, check
    the print quality. If the problem still
    exists, repeat the cleaning and test print
    procedures at least five times for the
    new ink cartridge. If ink is still missing,
    call Brother Customer Service.
  • 21 Answers
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Posted on Nov 05, 2008
How can I fix no cartridge error on brother mfc-465cn
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
Jul 18, 2014 | Brother MFC-465CN InkJet Printer
Mfc465cn-cant print test page,error PRINTER BUSY
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: How do print network configuration page Brother In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 22, 2014 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
My printer won't print black and doesn't know that there is a problem
Open the cartridge dor and take the black cartridge and check is the ink is there or not or is it dry. If they have any issue please change the cartridge. Try to take test print from the printer with our using computer.
Sep 23, 2010 | Brother MFC-465CN InkJet Printer
Black Ink Problem
try cleaning print head and nozzles and align the Print Head. If nothing the problem may be with your printer itself
Jun 13, 2010 | Brother MFC-465CN InkJet Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
I have a Brother MFC 465CN and cannot get the black ink to print. I have cleaned it several times, and am quite irritated! If i print a page from my computer, the colours come out fine, but not the...
Another user here suggested that you change the Media Type in Printing Preferences to 'Inkjet Paper' instead of 'Plain Paper' and this worked for me. Of course I don't know if it's pulling from the black nozzle or not, but I do get black now.
Dec 26, 2009 | Brother MFC-465CN InkJet Printer
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
Brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Oct 31, 2008 | Brother MFC-465CN InkJet Printer
Colour ink runs out and can't print b&w page
with all brother printers all the ink cartridges must be full or the printer will not print brother tech
Oct 27, 2008 | Brother MFC-465CN InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
2,080 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
