I dropped my hp laptop and now when i try to start it up i get error err1 and err3
  • 72 Answers
You may have damaged the Hard drive and or internal motherboard issue. Attempt to get warranty or send it into somewhere for servicing.
Posted on Mar 21, 2011
What is err1 and err3 in elekta dishwasher?
Electra Dishwasher Error Codes and other critical errors can occur when your Windows operating system becomes corrupted. Opening programs will be slower and response times will lag. When you have multiple applications running, you may experience crashes and freezes. There can be numerous causes of this error including excessive startup entries, registry errors, hardware/RAM decline, fragmented files, unnecessary or redundant program installations and so on.follow the instruction on the link below to find your solution http://www.saetechnologies.com/electra-dishwasher-error-codes/
Mar 03, 2015 | Dishwashers
I bought a used laptop and it shows Err1 Err3? it does not open windows
These errors can occur if the Sata Controller Mode Support BIOS setting is set to the wrong setting.
To determine if a BIOS setting is the cause of the error and to fix the problem, use the following steps:
  1. Turn on the computer and immediately begin pressing the F10 key repeatedly until a BIOS Setup Utility Screen appears.
  2. Press the Right Arrow key to select the Advanced window.
  3. Press the Down Arrow key to select Sata1 Controller Mode .
  4. The computer was purchased with a hard drive configuration in standard IDE formatting or as a Redundant Array of Independent Drives (RAID). Select the appropriate setting that matches the configuration that the computer came with: IDE (default) or RAID
  5. Press Enter .
  6. Press F10 to save the settings and exit.
  7. The computer opens Windows. If not, the computer may need to be serviced to replace the factory BIOS image.
Apr 05, 2014 | Computers & Internet
Esp-6tm controller shows err3 and err4 but one and five zones work. turned valaes on manually and the water comes out of heads. bad control box ?
When you say turned on valves manually, do you mean by operating the bleeders on the individual valves? If so, that has nothing to do with the electrical operation of the valves.
The fact that you are getting err3 & err4 leads me to believe that the wiring that electrically operate these valves are shorted.
Move the wires for valves 3 & 4 to terminals 1 & 2 on the timer and see what happens.
If err1 and err2 come up, the problem is in the wiring to the valves #3 & #4.
Gary
Jul 03, 2011 | Rain Bird Hardware & Accessories
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Please i need help with 2001 montero sports radio
if you put in wrong code 3 times the radio will shut down for a few hours will not let you do anything try again the next day
Mar 31, 2010 | 2001 Mitsubishi Montero
Err2,Err3 HP Desktop
If you go to this link it will provide you the drivers and recovery disc.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3633809
Its a HP website.
Jan 04, 2010 | Computers & Internet
Err2 display and no brew
The KitchenAid website states if it shows Err1 Err2 or Err3 try re-setting the power to the unit if it returns there is a problem with the electronics and Err4 is a stuck button. The Err2 is a heating element falure. Unfortunatley it may cost you more to fix than a new one. If it is less than a year old they may repair it under warranty but after a year your on your own. If you call them and complain that you have read a lot of other people online have the same problem they may repair it for you...Hope that helps.
Oct 03, 2009 | KitchenAid KCM511 Coffee Maker
I entered code# in book but shows err1,etc
Remove centre console drink holder then centre console watch for wires to cig lighter It all just unclips then pull firmly on ashtray assembly and you can get at radio Good luck
Jul 10, 2009 | 2001 Mitsubishi Diamante
HAIER HW-C1460TVEME-U
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
