Question about Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P
What weight oil do I use in Porter Cable 637 Type 1 Variable Speed Tiger Saw?
  • 604 Answers
Use sewing machine oil, or 3 in 1 oil, you could use WD40 as well. but not motor oil
Posted on Mar 22, 2011
How do you remove the fan from the armiture?
generally they are pressed on. make sure that you can buy a replacement fan, sometimes they are not available. Give me the brand and model number and I will check it out for you.
Mar 27, 2010 | Porter Cable Variable Speed Quik Change...
Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Need to change the blade on my sawsall
Make sure the cord is out of the plug! grasp the knob where the blade enters the machine, turn it 1/4 turn R or L and pull the blade out
Sep 29, 2009 | Porter Cable Variable Speed All-Purpose...
How do I replace the blade?
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Sep 11, 2009 | Porter Cable Variable Speed All-Purpose...
How to remove the blade on a tiger saw quick-change,model#737?
At the base of the blade where it attaches in the saw you will see a round in shape with ridges fixture. Turn it so the slot is in line with the blade. Then you will be able to remove the blade. If the fixture does not turn, move the blade up and down while you turn the fixture.
Jun 19, 2009 | Porter Cable Variable Speed All-Purpose...
Variable speed quit working
You would need to replace the switch, give me a model number and a location with zip code and I will try and find one locally for you, Its not that hard
Apr 25, 2009 | Porter Cable Variable Speed Quik Change...
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
Replacing shaft on tiger saw
If the spindle is broken you have to take the front of the saw apart, but check for excessive wear in the other parts before buying just the one. Its not that hard just pay attention when you disassemble
Nov 30, 2008 | Porter Cable Variable Speed Quik Change...
Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P Logo
107 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
