Question about Air Tools & Compressors
Air compressor will run ,but will not build up air pressure
  • 604 Answers
Make sure that your pressure control valve is not "popped open" if it was you would hear air escaping. also make sure that the knob on that valve is turned clockwise, otherwise you will get no pressure build up. It might be obvious, but also check for leaks.
Posted on Mar 22, 2011
Charge air pro model ir330e20 builds pressure to only 60 psi and will not stop running
Cbillgreene:
Your compressor is leaking air somewhere between the compressor head and the tank. With the compressor running, feel carefully around the ends of the tube that leads from the compressor head to the air tank. You will probably feel some air leaking around one end or the other. If so... remove the tube and find out which packing has failed.
Mar 09, 2013 | Craftsman Air Tools & Compressors
Coleman POWERMATE Lo502710. Compressor runs and builds up pressure and then keeps on running even when 100 PSI. It will not shut off. I do not hear a leak when I pull the electric plug to make it stop...
There is a problem with your pressure switch. You should have a little black box with a red lever to turn your air compressor on and off. This housing contains your pressure switch, the pressure switch sends an electrical signal to the switch to make your air compressor run. When enough pressure builds up the pressure switch activates, and breaks the signal until the pressure drops below a certain point. I will do some more research on your compressor and find out which pressure switch you need to order. i need you to find any numbers on the compressor you can, serial number, model, stock number, anything you can to help me find the part number.
Thank you for patience,
Calvin Smith
Nov 19, 2011 | Coleman Powermate 27 Gallon Air Compressor
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air pressure only builds up to 45 lbs. compressor continues to run. I drained all the air and it still only builds up to 45 lbs.
The check valve is not holding the pressure back off the head,therefore allowing the pressure to build up fully.
Jan 04, 2011 | Air Tools & Compressors
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Compressor will not build pressure
Have you tried adjusting the pressure regulator / also make sure that the over presser blow off is pushed in not popped/ do you hear air leaking ?
Apr 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
EC-12 runs but only builds to 35 psi and continues to run
It looks like there might be a knob which sets the max air pressure coming from the compressor. If there is one, this may have been turned down.
There are usually 3 pressure settings on an electric compressor. Compressor max, pressure switch cut on, and pressure switch cut off.
Apr 29, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Air compressor not building pressure
YOU MAY HAVE BROKEN OR CRACKED A FEED LINE REMOVE THE COVER LET IT RUN ,CHECK FOR LEAKS
Mar 05, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
166 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
