Question about Mitsubishi Televison & Video
Will not come on and timmer light is blinking
  • Mitsubishi Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck...
Posted on Mar 21, 2011
Timmer switch turns on but pump does not start. I have to go out and turn off timmer swith for a few seconds and turn timmer back on and pump usually starts auto matically. Some times when timmer switch...
The flashing re light is trying to tell you what is wrong! It will flash 2 to 9 times and you need to count the flashes and then refer to the troubleshooting chart on page 27 of your owners manual.
To me it sounds like your pump loses it prime some I would suspect a leak on the suction side of the system.
http://www.inyopools.com/manuals/210/IntelliFlow4x160_OM.pdf
Jul 20, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
The stand by /timmer is blinking, and I can't turn
If it blinks constant, your video path is defective,check IC301,but unplug it first.....hope this helps....
Mar 08, 2010 | Sony Televison & Video
The timmer light continues to blink. The TV will not turn on. This is after a power outtage. I have disconnected all the inputs and tried to reset>
Mitsubishi had a bad problem with capacitors going bad in there system control modules. Unless you like big CHINESE PUZZLES, best leave this one to a pro.
Oct 14, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Blinking timmer light mitsubishi 1080
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Jan 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
