Question about Brother MFC-7420 Laser Printer
Printer message says may need to replace drum soon. What is the difference between the drum and the toner cartridge?
  • 492 Answers
The drum is a metal drum that takes an electrostatic charge to attract the toner particles. Sometimes the drum can be cleaned. Taking it apart isn't easy. Sorry I don't have a better answer for you.
Posted on Mar 21, 2011
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
Is the "change drum soon" message instructing to
This indicator is for the drum unit, not the toner cartridge. The drum unit is the assermbly that the toner cartridge is inserted into when being replaced. The drum unit is replaced about every 18,000 pages so after about 5 to 10 toners have been replaced.
Here is a picture of the drum unit.
Oct 28, 2010 | Brother MFC 7420 All-In-One Laser Printer
K image drum
The drum and toner cartridge are two separate items. You need to replace the drum.
May 26, 2010 | OKI C5150n Led Printer
What is the Drum?
The drum is a selenium coated sort of roller that has the image of your copy document tranfered onto it. As it rotates this image is tranfered to your new copy paper. It then is demagnetised and the toner returns to the toner catcher. The drum coating has a finite life and the mesaage is telling you that its life is near its end and a new drum or new machine will be required soon.
Mar 22, 2010 | Brother MFC-9440CN Laser Printer
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a message that says "Change PC Drum". What is that?
This is telling you to replace the "DRUM" of the printer. This is different from the "TONER". Normally, the drum is attached to the toner cartridge. Check your printer documentation. You may be able to purchase a drum/toner kit. Drums last longer than Toner cartridges so you will replace the Toner cartridge more often than the Drum.
Jul 28, 2009 | Minolta bizhub 200 All-In-One Printer
Message received drum life end soon
The message means the imaging drum is going to need replacement soon. The imaging drum and toner cartridge are the two main parts that need replacement sometimes. In some printers the drum and toner cartridge are replaced in the same unit, but the Brother has separate parts. The drum is rated for a certain number of copies, so as it gets close you get the message. Replacement drums are available at big-box office places and online. An original Brother is in the $100-$150 range and generics around half that cost.
Apr 01, 2009 | Brother MFC-9440CN Laser Printer
Brother MFC-7420 Laser Printer Logo
104 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
