Question about Tools & Hardware - Others
Need specs. of belt lengths - Tools & Hardware - Others
  • 604 Answers
I'm not sure whagt kind of question you are asking. you don't list make nor model of sander. if you need a replacement belt, the easiest thing to do is to take the belt off and take it with you to your hardware store and that way you will be sure to the right belt(s)
Posted on Mar 22, 2011
Zanussi fls 1284 - how is it possible to make the right belt fit - I have tried and tried - it will not fit. What can I do?
It is elastic drive belt 1196 J5 which means that 1196 mm is the working length based on the belt mounted on the pulleys. "J" and "H" means shape of the drive belt and finally number after word (J5) means number of teeth (could be: 4,5,6,8) .The length marked on the drive belt (1196,1217,1280 etc.) is the working length based on the belt mounted on the pulleys. For a given working length, the belts - which consist of different materials - have a different degree of elasticity. This means that, when not fitted to the appliance, their lengths may be different. It is normal that the length of a plastic belt not fitted to the pulleys is three or four centimeters greater than that of a rubber belt. Also, both types of elastic drive belt are shorter than the working length and therefore it is a little more difficult to replace but not so much that you have to lossen motor.
Please follow this link:
https://www.youtube.com/watch?v=yC21q2-eAfI
Dado
Sep 13, 2015 | Zanussi Washing Machines
Length of belt with A/C bypassed 2006 impala LT 3.5 ltr
Best way I know is to take a string and wrap it around where you want a belt. Get the closest measurement you can. Then have the parts house measure string for a belt size. AND.... buy 2-3 belts near that size! Be ready to take some of the belts back. This will save you trips back and forth in search of a belt. There may be no exact answer to this cause as far as I know all came factory a/c so there will be no specs for a bypass.
May 27, 2015 | 2006 Chevrolet Chevrolet Impala LT
What are the specs on a 2006 suzuki blvd 800?
Try here:
http://www.globalsuzuki.com/motorcycle/moto/cruiser/vz800/spec.html
Overall Length U.S. & Canada specs. : 2,395mm (94.3 in.)
Other specs. : 2,420mm (95.3 in.) Overall Width 890mm (35.0 in.) Overall Height 1,105mm (43.5 in.) Wheelbase 1,655mm (65.2 in.) Seat Height 700mm (27.6 in.) Curb Mass 269kg (593 lbs.)
Nov 17, 2014 | Suzuki Boulevard Motorcycles
1997 Jeep cherokee larado squeals replaced the drive belt a few times and it keeps tearing
Inspect the belt tensioner for the following conditions:
Noise
  • If the belt squeals, the tensioner force may be insufficient. Check the belt length gauge, if the length is correct, replace the tensioner.
  • If the tensioner clatters or rattles during engine operation, there may be internal interference or wear. Replace the tensioner.
  • If the belt chirps, you may have a worn pulley or tensioner or cracks in the tensioner bas or arm. Check the mounting bolts, if they are okay, replace the tensioner.
Sticking or Seized Tensioner or Idler
  • If the tensioner does not operate smoothly or doesn't move, you may have: internal thrust surface damage/wear, internal damage/wear, or a broken spring, replace the tensioner.
Appearance
  • Inspect the tensioner arm for cracks or other damage. If the tensioner is broken, it should be replaced.
  • Look for excessive tensioner movement at idle, which can indicate internal wear, an out-of-round pulley or loose mounting bolts. Check the mounting bolts, it they are in good condition, replace the tensioner.
  • Make sure the tensioner is not tilted or misaligned. Also make sure a gap exists between the tensioner arm and base. If you notice a problem, check the mounting surface, it the surface is okay, replace the tensioner.
Belt Tracking
  • If the belt does not track properly on the pulley tracking surface, you'll need to troubleshoot the problem. Check the mounting bolts and the system alignment. Then, make sure the correct belt is being used for the vehicle. If all of these things are intact, replace the tensioner.
Belt Length Indicator
  • A belt length indicator is built into each tensioner.
  • The gauge identifies the effective operating range of the tensioner.
  • It consists of a pointer and either two or three length marks.
    • On a three-mark gauge minimum belt length, maximum belt length and ideal belt length are indicated.
    • On a two-mark gauge only minimum belt length and maximum belt length are indicated.
    • Ideal belt length on a two-mark gauge is generally half way between the minimum and the maximum.
  • When a belt wears and stretches with age the tensioner will move towards the maximum belt length to maintain proper tension.
  • As the pointer nears the maximum length mark, replace the belt.
May 04, 2012 | 1996 Jeep Grand Cherokee
Need to know length of serpentine belt to bypass A/C on a 1996 jeep grand cherokee 5.2 L
Take the old belt off. Place a piece of string around the pulleys in the correct routing location. The length of the string is the length of the belt you would need.
Mar 19, 2011 | 1996 Jeep Grand Cherokee
What length serpentine 8 rib belt goes on a 2001 jeep grand cherokee 3.1 td rhd
Not recommended to measure the serpentine belt...as to many variables...Your local Auto parts store should have your needed replacement in stock...best to be perfect on the dimensions...:) Your Make, Model, and engine are all the specs the Parts Team needs...:) Hope this helps.
Jan 03, 2011 | 2001 Jeep Grand Cherokee
Have akai ap-b110 turntable needs belt. Can you tell me the length/specs
  • If you have the turntable belt:
    • State the type of belt used (Flat, Square, Round).
    • Pinch both ends of the belt.
    • Measure the pinched length.
    • Multiply the pinched length by two (2x).
    • If the turntable uses a Flat belt, measure its width (usually 0.187").
    • If the turntable uses a Round or Square belt, measure its thickness.
    • Please include the make and model of the turntable with the belt's measurements.
  • If you do NOT have the turntable belt or it is shredded:
    • State the type of belt that the turntable uses (Flat, Round or Square).
    • Use a piece of string to tightly follow the belt's path.
    • Measure the length of the string.
    • Measure the width between the rims of the motor pulley that the belt can pass through (usually 0.250 inch).
Jul 08, 2009 | Audio Players & Recorders
Serpentine belt routing
Here you go.. I looked up the same belt you did, it should be right.
Feb 09, 2009 | 2001 BMW 330
I have a sony shelf system with combination cd and cassette - bel
Sorry, we have no belt listing for your specific model, but we do likely have what you need........
If you still have the old belt intact:
> Lay it out flat on the table
> Pinch it at both ends & straighten the belt but don't stretch it.
> Measure the length & then double it and choose or we will recommend
a size about 3-5% smaller.
Old belt too far gone to measure:
> Just use a piece of string and thread it temporarily in place of where the belt goes.
> Then measure the length of the string and Email us the exact length (inches). Along with your EXACT model number.
If your belt has a round or square cross section, please give us the thickness as well. We can assist
you in choosing a belt usually 3-5% smaller than the length you measured.
....from the turntableneedles.com site
Jan 18, 2009 | Sony CASSETTE DECK Single Dual Cassette...
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
