Question about Cameras
I just bought a Kodak mini video camera model Zm1 and it wont turn on. I charged it for about 1h30, the screen shows me that the battery is full but when I try to turn it on.. nothing. The screen stays black. I tried reseting it but didnt do any good. I just bought it today and didnt drop it or anything. Any solution?
SOURCE: dropped camera in pool
Open camera and place in a bag of rice for a couple of days to absorb moisture.It's worked before on cell phones.
Posted on Dec 16, 2006
  • 502 Answers
SOURCE: My Kodak EasyShare M753's screen is white with black lines
That must have been caused by a drop and I'm pretty sure your screen is gone. Try to send it back to Kodak they may not charge you if it's not obviously physical damage, if they refuse to give you warranty service there are third party camera repair places but they will definitely charge you.
Posted on Dec 13, 2008
SOURCE: Kodak z1275 easy share camera
never use kodak again!!!
Posted on Dec 17, 2008
Gurudristi
  • 98 Answers
SOURCE: one day camera just stopped turning on.
Try the following:
1). Check batteries whether they are fully charged.
2). Check with Battery terminal are clean. You can clean them with a ear bud using some alcohol or spirit. Wipe the battery terminal with a clean dry cloth.
3). confirm that the memory car slot/battery cover is securly closed.
4). Reload the battery several times. This will also remove poor contact between camera and battery terminals.
5).Check battery are loaded in the correct direction.
If the probem persists, you might need to take it to the service center.
Posted on Mar 02, 2009
  • 67 Answers
SOURCE: Kodak Easyshare camera model MD1063 wont turn on
hi,your camera needs a servise , its a lance problem just open your camera and remove the lance assembly and servise it properly , otherewise contact authorised person,
Posted on Aug 30, 2009
Will not switch on!
When you buy a new product you need to charge it at list 12h befor you turn it on .
Jan 27, 2014 | Kodak ZM1 Camcorder
Kodak camare wont turn on
same here it wont turn on but it will charge
Apr 18, 2013 | Kodak Mini DVC Digital Video Camera
I have a Kodak mini Zm1 that connects to the computer, but as soon as it starts to download the hardware it says that it is disconnected(which it isn't). I can't access any of the files on the...
When I want to download from my camera it has to be switched on and I have to open the camera menu and select PC before it connects to the computer and once it connects it shuts down so it doesn't run the battery down.
Sep 05, 2017 | Cameras
Bought a Kodak M340 about 6 months ago and it's been great. However, this time that I tried to charge it....it will NOT charge! When I plug it in, it flashes green once, then red three times, then nothing....
Hi , if your camera wont turn on with the power pack
you may try another one or battery that you no they are full charged, probly your battery charger is dead
if that not works you may have a problem whit your camera
hope that help
good luck
Mar 13, 2010 | Kodak EASYSHARE M340 Digital Camera
Kodak C180 for Xmas - The pic of the battery shows
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). The batteries that was in your pack when bought are only test batteries and not rechargeble.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 04, 2010 | Kodak EasyShare C180 Digital Camera
Kodak easyshare CX7430 my lens wont come out which i think is why the camera wont turn on?
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery for longer than 10 sec and turn on
Clean the metal contacts on the battery using a clean cloth
Due to KODAK no longer produce this camera model there is a lack of spare parts. Therefor a repair for this model isn't possible. However KODAK offeres a Trade up.
Contact KODAK:
Oct 19, 2009 | Kodak EasyShare CX7430 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Remove the memory card and the battery
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
May 28, 2009 | Kodak EasyShare Z700 Digital Camera
The camera wont turn on
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
Apr 04, 2009 | Kodak EasyShare C743 Digital Camera
Cameras Logo
362 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
