Question about Maytag MZD2766GES Side by Side Refrigerator
The refrigerator door will not stay close. Is there an adjustment that needs to be made? How can I fix this??
  • 3,018 Answers
Check the magnet seal around the inside pf the door and make sure they are grabbing. You can put the front legs of the fridge down a little more so it gives the doors a back swing when closing. Make sure your hinges are set plume (level) of the doors will not close right at all. Kids hanging on the doors will do this.
Posted on Mar 21, 2011
  • 1 more comment
  • Iron
    Iron Mar 22, 2011
    I looked for a while so I could locate a diagram to make this easier. I found one. Your switch is #28 towards the top.http://www.appliancepartspros.com/partse...
  • Iron
    Iron Mar 22, 2011
    You will have to copy and paste the link into your browser.
  • Iron
    Iron Mar 22, 2011
    I posted this in this link in the wrong place. My first solution is what I would try. Sorry about that.
Adjusting doors to stay closed
It is not a matter of adjusting the doors. It is a matter of adjusting the legs so that the front legs are taller than the back. This causes the entire refrigerator to tilt toward the back, which is what makes the doors close by themselves. Your installer should have done this for you, as it differs between locations. It takes at least 2 people to do this: one person tilts the refrigerator back by pushing on the front of the freezer door, and the other person carefully rotates the front legs of the refrigerator until they lengthen about 1/2 inch - each! You might have to slide the whole refrigerator forward to give you some space behind it to allow tilting. Don't adjust the rear legs - not needed unless someone has unthreaded them in error, or for some unknown reason.
Oct 21, 2012 | Frigidaire FRT21P5A Top Freezer...
Refrigerator door will not stay closed
HI MANDY.normally the gasket dont go.it's rare.i would think u'll need to check the bottom door bush.parts difficult to get.u'll probably need to get a MANMADE ONE.good luck ali
Jul 12, 2012 | LG LSC26905TT Side by Side Refrigerator
MZD2766GEQ - MAYTAG Side-by-side refrigerator fresh food door will not stay closed? hinge or gasket? inside seal?
Normally the most common fix for the doors is to level the cabinet. Leveling the cabinet will also adjust the doors to help level them and help them close properly.
May 04, 2011 | Refrigerators
Door needs to be adjusted as it seem to be hanging lower on open
slightly loosen the bolts on the hinges enough to scoot the door into the correct position and it will stay until you tighten the bolts on the hinges. It may take a couple of tries but that is the way to do it until the door seals and closes properly =)
Jun 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
The refrigerator door (not the freezer door) does not close.
Is it closing flush when pushed up or is it not making good contact all around? 2 things can be wrong, the surround needs to be cleaned on the door and fridge and if it still doesn' stick you will need to replace. You can adjust the door slightly at the hinges but only if its loose should you need to. If its tight then it has not shifted and i would focus on the surround clening/replacing first
Oct 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrig door stays open
Your refrig has legs you can adjust down ... this will tilt the refrig to the back so it will close be itshelf...
hope it helps let me know if it helps
Sep 26, 2009 | Refrigerators
Side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
Door will not stay closed
Try tilting the fridge slightly back, or use a spirit level or plumbob at back, non-curved vertical case of fridge to align.
The base should have adjustable feet for levelling.
If tilting forward, even a fraction, gravity will open it.
Dec 19, 2017 | Kenmore 91493 Stainless Steel Compact...
Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Maytag MZD2766GES Side by Side Refrigerator Logo
119 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
