Connect your iPod to your computer with the USB cable that came with your iPod. The iPod screen should say "Do not disconnect".
Your iPod should appear under Devices in the bar to the left.
Decide whether you want to sync your iPod with your iTunes library or manually put songs on your iPod.(nano only)
Syncing your iPod will automatically add all of the songs in your library to your iPod. It will also delete any songs from your iPod that are not in your library. Click on your iPod icon and select Sync in the lower right corner.
If you do not want all the songs in your library on your iPod, make a playlist of all the songs you do want, or decide which playlists you want to include on your iPod.
On the top bar, click on the button which says "Music"
Make sure the box that says "Sync Music" is checked, then check the box for whether you want your iPod to sync with the entire library or selected playlists. If you click selected playlists, select the playlists you want in the playlists category. For newer iPods you can check which artists are included on your iPod to automatically import all the songs from each selected artist onto your iPod
Step 1: Launch iTunes on the computer. Ensure it is the latest version. You can go to "Help > Check for Updates" on iTunes.
Step 2: Click "File" and then "Add file to Library" to import your music to iTunes library.
Step 3: Using a compatible USB cable, connect your iPod to the computer. Click on the device tab.
Step 4: Choose Music from the left sidebar.
Step 5: Check Sync Music and select the playlists, artists to transfer. Click Apply to begin the syncing process.
More perspicuous tutorials for iPod users:
https://bit.ly/3eTYfQD
https://bit.ly/3eX1dDO
