Question about Car Audio & Video
I am installing the CD Reciever in a Vintage Airstream Travel Trailer. The power wire, ground wire and speaker wires, should be no problem. (Neg ground) do I need the Mute, Illumination and remote? I only have the diagram on the box with the color codes. Can you advise? Thanks. David Stokes.(stokescyn@cox.net)
  • 635 Answers
1)The mute cable is to mute your CD Receiver when you get a call on your mobile phone. You will have to buy a car mobile dock for your phone and it will have a mute wire on it, which you will have to connect to your CD Receivers mute wire.
2) The illumination wire is to be connected to the headlight switch of your car. In some CD Receivers it will turn on the display at night along with the headlight. On some models it dims the back light at night along with headlight so that the bright light which is needed during the day does not distract your driving at night.
3) Remote wire is for triggering another device along with the CD Receiver,like an additional power amplifier or a Sub woofer etc.
Posted on Mar 21, 2011
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
Pioneer AVH-P3400BH install in travel trailer....how to wire parking brake bypass?
no since u don't know what the green wire is call pioneer customer support they help me a lot
May 24, 2012 | Pioneer AVH-P3400BH Car DVD Player - 5.8...
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Mar 14, 2011 | Car Audio & Video
Hi there, I bought a 2007 electra glide fairing w / harmon kardon radio . Which wires on the 23 pin harness do i use for power,ground, & speakers. I have a 99 Kawasaki Nomad 1500 that i installed...
If it is the basic radio then here are the wiring pins for it:
RT FT Speaker - Pin 18
RT FT Speaker + Pin 1
LFT FT Speaker + Pin 16
LFT RR Speaker - Pin 17
Power and Neg pins are Battery Pin 10, Ground Pin 11
Ignition Pin 12
Another Power & Neg pins are Battery Pin 19, Battery Pin 20
These are the Pin Connectors for the stereo.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
Mar 14, 2011 | Harley Davidson FLHTCUI Electra Glide...
Instructions for wiring a moving trailer connector
Trailer Wiring Diagrams 4 Way Systems
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4%20way%20wiring.jpg 4way_vehicle.jpg 4 way tow vehicle side.
4way_trailer.jpg 4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5way_vehicle.jpg 5 way tow vehicle side.
5way_trailer.jpg 5 way trailer side.
6 Way System, Rectangle Plug 3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6way_rectangle_1.jpg 6 way tow vehicle side.
6way_rectangle_2.jpg 6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6way_vehicle.jpg 6 way tow vehicle side.
6way_trailer.jpg 6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7way_vehicle.jpg 7 way RV flat blade tow vehicle side.
7way_trailer.jpg 7 way RV flat blade trailer side.
Jan 01, 2011 | 2001 Pontiac Montana
Have a 1998 wild travel trailer and need to
Hello. I can help you. Your gas furnace only needed a small amount of electrical power to operate. The electric heater on the other hand will need a lot more power and most likely will need 220 volts as opposed to 110 volts for the gas furnace. Therefore, a new line to feed your electric heater, sized appropriately will have to be run from the electrical panel to the electric heater. I recommend that you have a pro do this wiring job for you as there is no room for error. Good luck with it.
Nov 01, 2009 | Electrical Supplies
We had a clarion reciever with tape deck in our boat and found another clarion reciever with two new speakers and two good 1996 speakers which had not weathered. The instalation was difficult but the...
As long as you have connected the ground(black) try adding one wire at a time to the live(red). If possible try connection each wire one at a time to the power line and then both together. If nothing has blown(fuses) and the unit starts working then you can try by trial & error method the remaining wires. You should be able to figure out which wire is required and if there are any extra wires like cellular phone(mute) and then decide whether to connect them or keep them open.....sodeep
Jul 27, 2009 | Clarion DB245 CD Player
Installing CD Player
i supose the am fm radio just dosnt cut it anymore well lets give this a try . first u must disconnect positive battery cable so you dont short any wires . remove screws that hold in factory radio pull radio out a feww inches as no to rip out any wires.next you must locate positive 12 volt power supply wire usually red or orange .if not shure connect battry cable again and use a 12 volt test light by attaching the ground cable on the test light to a good clean metal bracket under dashboard or connect to a black groundwire with a screw into the steel under dash next probe the wires goin into the factory radio ur looking to find power 12 volts once you have found the correct power wire use tape and mark it this will be the power wire for your new stereo next u must figure out what wires for what speakers osually 2 wires per speaker 2 rear speakers and 2 front speakers meaning a total of 8 wires follw me so far ? now disconect car battry again so not to have sparks and cut or disconnect remaining wires speakers first label all with tape and mark front right front left rear left rear right there is a + and - the wire with the stripe on it is usually the + the other wire is the - being negitive ground . this operation is important in order for your fade ballance controlls to work properly now with your new cd player inhand look and see what wire is gonna be 12 volt most times its red with a fuse eg white plastic connector small fuse inside there it a must proper fuse to protect new cd player now there will be a black negative this will go to the matal ground area under dash close to where cd player goes into dash red to the orig taped 12 volt supply now ur spks one pos+ and one neg or common to each speaker now make all conections with stereo before you push stereo into dash you must hook up car battry leaving cd player hanging out so you can make wire changes if you wish on the speakers you need to use one pos front right or rear right + with one common or neg black - to the spkr the same common or ground or - whatever its called one common or neg can be used for all spkrs .good luck tape and solder all connections after you feel all is good im sorry this is all the help i can offer you be careful
Jun 12, 2008 | 1978 Ford Granada
Wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Nov 16, 2007 | Pyramid 903G 10-Band Car Equalizer
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
