Question about Coleman RoadTrip LX Grill 9941-765
Is the regulatior suppose to thread into the line to the burners
  • Coleman Master
  • 8,220 Answers
The regulator is supposed to reduce the gas pressure from the supply can. So it is the first thing after the gas enters into the grill. without it you would have a flame thrower or worse.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 21, 2011
Pilot light is strong with no problem. Cut on main burners and pilot flame diminishes and barely touches thermopile causing main burners to go out. Pressure to unit is good and flames good
Take off the gas line and look to see if too much thread sealant was used on the gas line. Pressure may be good, but that doesn't rule out the pressure regulator.
Mar 17, 2016 | Kitchen Appliances - Others
How do i change nozzel on oil burner
Turn power off and isolate the fuel line/lines. Disconnect flare fitting on fuel line to the burner assembly. Open burner assembly...either the primary controller or ignition transformer should hinge open with a few screws on the other side. Should be a locking nut on the fuel line to the burner and electrodes...loosen and pull burner/nozzle/electrodes. I Don't recommend removing the electrodes if you don't know how to space them correctly, so unless you have a nozzle removal socket/ratchet, then use a deep well socket & back it up with a large pair of channel locks. Thread pattern is normal...LLRT. When replacing nozzle, Make sure you have the same gallon rated, spray pattern (hollow, semi, solid etc) , & degree (angle).
Jan 19, 2015 | Kitchen Appliances - Others
How do I swap the nozzles
Although converting the fuel in a typical barbecue is very simple it can create a very dangerous problem if done incorrectly. Many bbq companies do not permit fuel conversions because done with a know-it-all attitude instead of getting experienced, licensed assistance can be dangerous.
The "nozzles" are the gas orifices and the orifices have a small hole drilled to limit the maximum amount of gas flow into the burners. The orifices are almost always threaded to the tip of the control valve where the valve inserts into the burner venturi tube. Occasionally the valve will have an extension gas line between the tip of the control valve and the burner and in this instance the orifice will be at the end of the gas line where the gas connection slides into the burner.
This is the same in side burner range tops but in a side burner the orifice can usually be accessed by lifting the round shield and burner on the top of the side burner instead of following the gas line from the valve.
Oct 10, 2014 | Grilling
Are the metal tube lines from the knobs to the burners supposed to be attached?
This is a very intersting vacuum cleaner you have my friend.
If this is n fact not a vacuum cleaner ... but rather ... a stove ... no ... the metal tubes are not solidly connected to the knobs and burner.
Dec 07, 2010 | Vacuums
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Burner wont read any disc
you burner is suppose to read disks even when its not on a pc. check that out, ie disconnect it from the pc and insert a audio cd jus to check if it reads the cd, its suppose to spin and not stop. that shows its reading. if it doesn't then its dead. you will need to replac it
Dec 09, 2009 | NEC ND-3550A-KIT DVD±RW Burner
1999 Saturn SL2 drivers side window doesn't go down all the way then makes a grinding noise, when put up makes a grinding noise
It sounds like there is somthing wrong with the window regulatior ( the motor in the door that moves the window)
1.Remove the inner door pannel (all parts)
2. hook up the window controls & try moving window up or down, make sure window is moving propley in tracks and siscor arms are not bound up.
3.If all is well with the above stuff, just replace the window regulatior and test befor you reasembil the door pannel
Feb 25, 2009 | 1999 Saturn SL
Gas dryer
be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
Jul 16, 2008 | Whirlpool LGR5636PQ Gas Dryer
Whirlpool water heater thermocouple
Nope, turn off all gas to the heater. Remove the enclosure containing the burner. Disconnect both the gas line and the thermocouple line from the gas valve and pull out the whole burner assembly. Take a pair of needle nose plyers and remove the thermocouple from the pilot assembly. Install the new one and reverse the removal procedures to put it all back together. Check to make sure there is no gas leaks and this is important, The nut to turn off the burner tube from the gas valve is reverse threads. Righty to turn off, Leftie to tighten.
Nov 20, 2007 | Heating & Cooling
STS Turbo heat problem
Problem solved. The store FINALLY sent someone out who knows what they're doing. After about a hour of adjusting and tweaking he got it working fine. Apparently, the adjustments have to be made with the grill partially disassembled so flames can be viewed from top and bottom. Also, it needs to be load balanced with adjusting with all burners on, then with fewer and fewer burners on. Dan B.
May 26, 2007 | Barbeques Galore Turbo Elite 4-Burner with...
Coleman RoadTrip LX Grill 9941-765 Logo
169 people viewed this question
Top Coleman Grilling Experts
Paul Carew
Charles T Nevin
Charles T Nevin
john h
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
