Question about Toshiba Satellite A215-S4807 Notebook
I PLUGGED IN MY LAPTOP ADAPTER AND THE PLUG LIGHT BLINKS BUT DOES NOT POWER UP. THE PLUG ICON ON LAPTOP BLINKS BUT LAPTOP WILL NOT BOOT UP.
    Scholar:
  • 115 Answers
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Posted on Mar 21, 2011
I have a samsung R620 laptop but the laptop is not booting but the battery and ac adapter are working properly on the system because the battery light shows or indicate tha the battery adapter is okay but...
By pressing power button it is powering on or not if yeas the display light is comming or not? if yes then what is the bios error code please check. If not powering on then remove the battery plug in power adapter and press power button if not on then it is hardware problem go to service centre
Sep 13, 2017 | Samsung R620-64BR Laptop Computer
Tha half moon light blinks green,standby light also blinks with battery light orange light when charger is connected to my thinkpad t61p ,no booting
Step 1:
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Feb 17, 2013 | Lenovo ThinkPad T61p 15 inch widescreen...
Acer Aspire 553, plugged in but when i highlight the power icon in the tray, it says 'Plugged in, not charging'.
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 25, 2011 | Acer Aspire 5535-5050 Notebook
When you press the start button nothing happen not light or start up
First remove the battery and put it back in, you want to make sure it has a good connection.
Next you want to check the power adapter. If it has a built in LED light, it should turn green when plugged into the wall. If it does have a light and the light will not turn on or it blinks, replace the adapter. Next, plug the adapter into the computer, does the LED light change? Example, the LED light was a solid green, when you plug it into the computer it blinks. If the light does something along those lines, then there is a problem with the laptop itself.
If the power adapter does not have an LED light, then you need to use a Multimeter to check if the adapter outputs the right amount of power...which should be around 12 volts.
If the battery and power adapter pass the tests, then you are looking at a hardware issue in the laptop. From your description of the problem, I would guess the motherboard has died or that the charging jack on the motherboard came loose and needs to be replaced or re-soldered.
Two things that would stop the light from coming on, No Power or Motherboard is broken.
May 02, 2010 | Toshiba Satellite M45-S169 Notebook
IBM Thinkpad T42. About 1hr ago went black-dead. When the power supply is plugged in there is no icon illuminated. No power reaching anything. Recently have had some fan-error warnings and have been...
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 02, 2009 | IBM ThinkPad T42 Notebook
Dell latitude l400 mother board power problem
SOLUTION  # 2:
The  adapter can be plugged into the DELL the wrong way and it won't charge then. I've done this myself so check to see if the adapter plug that goes into the laptop has a grey battery icon on it. The icon goes on top when you plug it in. For different laptops the symbol may be different than what I mentioned.
Aug 18, 2009 | Dell Latitude L400 CMOS Battery (7.2V,...
Laptop won't start
You didn't mention the brand? First, take out the battery and plug in the AC adapter. Does it boot?
Leave the battery out of the computer a couple of hours, now put it back in and connect the AC adapter. Does it boot? If you still get nothing the computer needs to see a reputable repair person.
Apr 04, 2009 | Computers & Internet
Power light blinks
Try using a different AC power adapter. It sounds like the laptop is not getting the proper power or not getting any at all. Have you taken out the battery and tried to power the computer on while plugged in? Also, take a pen or something similar and see if the DC jack (place on the laptop where the power cord plugs in) moves or appears loose.
Mar 18, 2009 | Toshiba Satellite A215-S4747 Notebook
Laptop will not boot
ok, take the battery out and leave it unplugged for a few hours.  Only plug the ac adapter in after.  Press and hold the power button for 10 seconds.  Does it still do it?  If it does work, then chances are your mobo has bit the dust or you have knocked loose an internal charging part.
Mar 09, 2009 | Compaq Evo N410C Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Toshiba Satellite A215-S4807 Notebook Logo
284 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
