power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
Hello.
Unfortunately there is no way around this. It is a feature of the printer to stop any air reaching the tubes to the print head from the cartridge, plus a way of making you buy more ink!
If quality is not an issue search on E-bay or a computer fair/market for some cheap compatible cartridges. I have seen them from $10-$20 each
I hope this helps
Regards GM
HiI found this I know your error not in here but it may work for It worth a try nothing to lose and it may work.I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm itError code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product: 1.Without turning off the product, disconnect the USB cable from the rear of the product. 2.Remove the cartridges from the product. 3.Wait for the 'Insert Cartridges ' message to display on the control panel. 4.Disconnect the power cord from the back of the product. 5.Wait 60 seconds. 6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ). 7.Reinsert the cartridges, and then close any open doors on the product. 8.If you receive a prompt to print a calibration page, do so. 9.Reconnect the USB cable to the rear of the product, and then try printing again. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
The OK-cancel-black-color procedure is to be done when turning the printer **OFF** not on.
Then when you turn it back on you'll see "NVRAM RESET" (or something like that) on the display.
It might take a couple of tries.
This is a fix if the problem is not a hardware failure. This same "ink system failure" error also displays if there is a hardware failure and this cannot be corrected with the button/power off technique.
Good luck.
