Question about Keyspan (USA-28) Serial Adapter
Kkl][l,,,,,lkk[[lll[l[ll[l\\..]]\ ]mmmmmmmmmmmmmm
How to fix digital scale reading LLL
LLL probably indicates "Off-Level".Take batteries out / unplug power,re-apply power and make sure scale is Level....LLL also might indicate power is Low....make and model # ???
May 09, 2017 | Health & Beauty
How to change the language from danish to english?
You can change the language by reformatting the unit.
Aug 18, 2014 | HP 2133-1 Mini-Note PC
Dayton 3 speed switch 34g191 has no wires or diagram. how do I hook it up.
2a5da9a5-aac3-42c6-abd8-aafc5120b40f.jpg205419c3-0ab0-44b2-af3d-75ca1d7c5061.jpg30a6a9a2-5d9a-485b-aa23-85f37da6902a.jpgDayton fan motor 6C539A Grainger switch number 34G191. Luckly I have two fans. So when the one I went to pull out fell apart before making anything I pulled the other one apart. Okay, on the white plastic there are numbers l(1), ll(2), lll(3). Orange wire l(1), nothing in ll(2), blue wire lll(3). Now on the black plastic, the outlet wires go here: black wire L, white outlet is 180degrees (by orange wire) NEUTRAL SPLICER. Now, white wire from motor goes into the other side of the NEUTRAL SPLICER next to the black wire on the black plastic. This is just above the ll(2) on the white plastic. REMEMBER - NOTHING GOES INTO THE ll(2) ON THE WHITE PLASTIC.
May 02, 2013 | Dryers
Ll;lkk;klj;klj;;kl
what seems to be the problem?
Sep 19, 2011 | Computers & Internet
How can i lock my keyboard on my laptop?
http://www.100dof.com/kidkeylock.html
download and install it.
Double-click on kkl (kid-key-lock) icon in system tray. Configure mouse & keyboard as per your wish. (my suggestion, dont change any passwords)
To undo it, just type kklquit.
For next use, start kkl (All Programs - kkl), type kklsetup.
Windows also gives you a way to lock keyboard.
Press Windows+U.
Go to "Make the keyboard easier to use"
Check "Turn on filter keys"
Apply
Keyboard is locked. All you get is beeps when you type.
To undo this, double click the new clock-icon in system tray.
Uncheck Filter Keys.
Hope my solution helps you.
Nov 15, 2010 | Computers & Internet
Hi,i need power steering fluid for my 2000 kia sportage, the manual sais i need dexron 11 or 111 but nobody local sells it. is there an equivelant?
dextron is transmission fluid and the 11 is not eleven its 2 [ ll ] and 111 is 3 [ lll ] all automotive stores carry it even gas stations-some hardware stores
Aug 22, 2010 | 2000 Kia Sportage
I'm tying to find the towing capacity of an 01 toyota tundra sr5
depends on the hitch class l class ll class lll class lV class V
Mar 03, 2010 | 2001 Toyota Tundra
Keyspan (USA-28) Serial Adapter Logo
278 people viewed this question
Top Keyspan Computers & Internet Experts
David Payne
David Payne
Are you a Keyspan Computer and Internet Expert? Answer questions, earn points and help others
