Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619
The lock quit working (no lights on keypad) I installed a new battery but it still doesnt' work. The keypad doesn't light, like it is not getting any power. I checked all the connections?
  • 963 Answers
Reprogramming BE 365:
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
Posted on Apr 18, 2011
95 ford explorer battery went dead due to lights being left on, now keypad doesnt work
try closing and locking all the doors then unlock the drivers door with the key
Feb 26, 2012 | 1995 Ford Explorer
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Schlage FE 595 - - Just quit. Changed battery, codes, etc. Get green blinking light - hear click - doesn't engage. Disassembled - spring good, slides work, placement of round headed pin could be the...
Electronic Security.....
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Nov 15, 2010 | Schlage FE595-CAM-ACC FE595-CAM-716-ACC...
The problem i am facing with my new nokia E75(BLACK SILVER) is that,it's keypad light doesnt gets on while dialling the number,,,,i am not talking about the QWER keypad but the normal alphabetical...
The Phone is fine all keypad lights only come on when you are in a dark place it works on a sensor I assume this is a feature created by Nokia to save battery power
Oct 27, 2009 | Nokia E75 Cell Phone
Powerbolt 1000 started beeping and quit functioning
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Jun 14, 2009 | Weiser Lock Powerbolt 1000 Lock
Garage Door Remote Openers Stopped Working Suddenly
Check the wall control. If the small green light is blinking press and hold the button with the lock icon for 3 seconds.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad doesn't light up.
If this is a battery operated lock then the backlight doesn't stay on (otherwise it will wear the batteries out). To make the keys light up when you want to enter your code you have to push the lock button on the keypad first. If the keypad light has never come on then open the door and manually lock the interior lock then press the keypad lock button then the above instructions will work. This is the solution I got from Kwikset customer support and it worked for me. Hope this helps you.
May 19, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619 Logo
551 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
