Question about Apple 20" iMac Desktop
The screan has lines going down it, and the color just completely like.. exploded yesterday now its all fuzzy and shaking and u cant read anything, i can makeout the shapes but its crazy
  • 187 Answers
Kindly check if on the BIOS you can still see those lines...if it is still there obviously it is a screen issue
Posted on Mar 21, 2011
Hi, I have a Goodmans 32" TV LD3255HD. we have a
start by checking capacitors, if the have exploded replace them
if not then may be another board probem
Aug 25, 2013 | Televison & Video
I adjusted the color on my Display settings and now I can hear but cant see out of range Megahertz?
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 11, 2012 | HP Computers & Internet
Fuzzy line going right down right side of Sony Laptop VGN-CS26g
The pixels inside of the LCD are going bad. Your screen is going to need to be replaced. When pixels in screens go bad it usually turns colors or gets fuzzy after it heats up.
May 14, 2010 | Sony VAIO VGN-CS260J/P Laptop
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
I have a HP PL4260N TV. When I turned it on, it
Before doing anything to your TV, try to reorient your
antenna. Then, if nothing happen, you may now call
service to adjust or replace component part.
Sep 25, 2009 | HP PL4260N 42 in. Plasma HDTV
Dell Inspiron Screen Shake
sorry, can't tell you "no cost fix".
Either you've got a motherboard-screen cable failure(harsh, but not too bad) or you're
video card is fritzing. The green/grey line usually indicated a line break in a data line of the monitor cable. The fuzzy shaking is an indication that one of the sync signals may also be compromised.
To eliminate the video card as the problem... plug a monitor into the external video port, and see if the error is ghosted there.
If this doesn't work, Dell actually has some pretty good tools for you to use in troubleshooting it for yourself. The troubleshooter page begins here. There is a good video of using dell's built-in-to-laptops LCD screen test utility here.
Hope it helps you.
Jun 01, 2009 | Dell Inspiron 1420 Laptop
Skewed printing
Most probably you have to do the Color Registration Settings and the Color Calibration.
The Color Registration will fix the fuzzy printing and the Color Calibration the way how the colors looks. The Color Calibration it is done automatically after each batch of 40 or 80 pages and if you need you can do a manual Color Calibration BUT THE COLOR REGISTRATION must be done manually.
Go to Menu->Others->Service->Color Registration and print a test chart. Will print a page and you have to read the alignment of some lines Cyan Magenta Yellow Black with some numbers. Check the Advanced user guide for details. Basically you have to read the number / letters of each color where 2 lines are matching. Then you can enter those numbers into the printer for each color.
If the Cyan only is off then will be easy ...
Nov 03, 2008 | Kyocera FS-C5030N Led Printer
Crazy Screen
Check and replace the T'con board. It is faulty. If you wish to get some details; visit the site linked here. Pull up older posts.
May 21, 2017 | Samsung LTN468W 46 in. LCD Television
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Printer prints each line 3 times
There are a number of possible reasons for the problem you are experiencing: 1. The printer head might need alignment - use the printer?s software to align the heads 2. Does the problem occur with different cartridges? Try with an old cartridge before opening a new one. 3. If the ink is smeared you might want to clean the printer - make sure no hair or dust balls inside.
Aug 23, 2006 | Compaq Inkjet Ij300 Printer
Apple 20" iMac Desktop Logo
109 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
