Question about LG WM-2277HW Front Load Washer
I have a LG wm2277hw washing machine. the drum will spin a little and then make a scaping sound like friction. The drum has a lot of play in it. Is there a hard plastic washer or shim that wears out. The pump filter had grey pieces in it.
  • 185 Answers
Sounds like your drum bearings and seals are shot, you will need to replace the rear outer drum ***'y and possibly the shaft/spider; (if the shaft is rusted to the inner bearing races). in any case; it's not a cheap and easy repair.
Posted on May 16, 2011
    President:
  • 670 Answers
The symptoms that you describe sound like the spider or support arms of your washer has failed. It the part that holds the wash drum true in the plastic tub. It's a rather difficult job to replace the spider since the washer has to be taken apart to get to the spider. Fortunately, LG does sell the spider, instead of making you buy a new spider and drum. You may need to also replace the plastic tub parts if they are too damaged to be reused. Get a few estimates before deciding whether to repair or replace.
Posted on Mar 22, 2011
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
LG Tromm WM2277HW drum was noisy, then wobbly and now has stopped spinning
Remove back cover and check for a loose nut that holds the rotor. you may have to replace the rotor( is the cover that holds the magnets). Not the stator (which is the motor.)
Apr 28, 2014 | LG WM-2277HW Front Load Washer
Lg tromm wm2277hw will not spin
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously to enter QC test mode and check the frequency of the water level, if the display shows 248 or more:
NO: Check the sensor switch assembly and also the pressure hose, replace either if faulty.
YES: Press the START/PAUSE button twice while in QC test mode and check whether the drum spins at low speed, this is normal.
If no reaction from the drum at all the the main PWB assembly board will need replacing.
Feb 09, 2014 | LG WM-2277HW Front Load Washer
LG Tromm Model WM2277HW washing machine not operating right
It is possible that the drum is off center, shifted in the alignment and had a friction at the base of the drive. It is possible that there is bearing failure or there is a fault in the drive. If you experience that there is friction manually even with a hand turn then the assembly must be reset. check this link for tips: Bearings
Feb 12, 2013 | Washing Machines
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
My LG washer wm2277hw does not drain water and
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | LG WM-2277HW Front Load Washer
Our LG Tromm Washer is struggling to spin. Humming sound in the beginning and then displays LE on the panel. Heard it may be the Stator Sensor/Part. Any Advise please!!!
Definitely the Stator/Sensor/Hall switch. Go to http://www.mcminone.com and order part number 6501KW2002A (if your machine is model number WM2277HW). Remove rear panel, remove three retaining screws for sensor wires at left bottom of drum, remove drum outer retainer bolt in center, stator assembly is now exposed. Remove bolts holding stator assembly (I think there were six) and replace switch assembly by lightly prying tab locks off of stator. Press on new switch and reassemble...
Jan 23, 2010 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
LG WM-2277HW Front Load Washer Logo
459 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
