Question about Leviton MFG 041-05226-00I ELECTRICAL SWITCHES AND PILOT LIGHT
Push button desk lamp switch --the button broke off
Add in-line switch to cord, available at home center.
http://www.uniteduniversal.com/images/product/000_0143.jpg
Or put lamp on a remote control
Example of remote control that I use:
http://www.amazon.com/Woods-13568-Wireless-Control-3-Outlet/dp/B001Q9EFUU
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on lamp or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 30, 2011
My tornado lava lamp doesn't work. A little plastic piece just bounces around on the bottom.
It's difficult to say based on your limited description. A lava lamp is a first of all, a lamp. Does the incandescent lamp light up? If not, replace it (it's the heat source which creates the swirling action in the attached "lava" globe). As for the plastic piece, perhaps it's part of the lamp-holder socket that broke off due to heat. Perhaps part of the switch.
In any case, the light light bulb probably burnt out. Believe it a standard 40 watt bulb, but be absolutely certain to check before replacing as you do not want to put a bulb with a higher wattage in there due to the confined space inside the lamp.
Apr 13, 2014 | Novelty Lava Desk Lamp
Tensor Desk Lamp with magnetic off & on switch stopped working. How can I fix this
Do you have the model number? This is most likely not the switch. There is a problem with the power suppply. IT uses capacitors that have been substandard and may have failed.
Dec 04, 2013 | Tensor 2 x 3W LED Desk Lamp
Lionel train desk lamp not working consistantly.
There are 6 rubber foot pads that under each one is a screw. I had the same problem and we found out that there were screws under the rubber foot pads. Once we were done we glued the rubber foot pads back on the lionel lamp. (Lionel Train Desk Lamp)
Apr 21, 2013 | Toys
Power on problem
1) test the outlet wall plug a desk lamp for to see if word, if does goto
1a) test the power cord
2) test the main switch for open or defective
3)go to the power supply see if the blown fuse replace or c.breaker reset.
4) if the problem persist, see for short in diode, transformer, filter, coil,rectifier.see the block diagram
God bless you
Aug 01, 2012 | Mitsubishi WS-65819 TV
Can I turn the lamp on fron a switched recpt or do I always have to push the button on the lamp?
I think you still have to push the button even if the power switch is on just to kinda get everything started, It will turn on the light & any neat movement &/or sound effects that it makes will happen & if it's anything like my daughters lamp that's similar to this, if you push the button a second time, music and sound will happen again but then the light will shut off. I'm not positive that i'm correct & apologize if i'm wrong but my daughter has a Disney dancing princess lamp & thats how it worked. It also had a switch to turn on or shut off the sound so i hope I helped somehow now that i've written a novel that should have been 1 or 2 sentences. Sorry
Jul 03, 2011 | KNG America KNG Disney Fairy's Animated...
My ask proxima c180 does not power up. I have confirmed the power cable is firmly inserted. When I press the power button nothing happens
take the lamp door off and manually hold in the safety switch.(if you look at the lamp door and see the post, the post is what pushes the switch in normally) while holding the switch in, push the power button. try the button on the projector and the remote. if the unit powers up it means your lamp door is miss-shapen from the heat from the lamp. if this didn't fix you problem, you need a power supply.
May 27, 2010 | ASK Proxima C180 Multimedia Projector
GE desk speaker phone model #2-9390A (NOT cordless) we cannot activate the speaker feature - any helpful hints? carole
There is not a programmable mute function on this phone so unless it is broke you should just have to push in the speaker button to answer the phone or push it and hang up to activate the speaker function. Hope this helps you.
Mar 29, 2009 | GE Lands Phones
99 Blazer-push button 4wd not working
Make sure that all 4 tires have the same tread on them, if one or more of them are different, then the 4wd may not engage. I had the same problem with my blazer, I changed only 2 tires at a time. The front tires would rotate faster than the rear ones, the gears in the transfer case won't line up right.
Dec 06, 2008 | 1999 Chevrolet Blazer
Lamp Nec mt 1050
i have a mt1020 and the switch for the lamp cover might be the problem,find the switch with cover off. push up with small screwdriver, if this works just add some tape to the arm on the cover that pushes the switch up...
Jan 17, 2008 | Office Equipment & Supplies
Leviton MFG 041-05226-00I ELECTRICAL SWITCHES AND PILOT LIGHT Logo
113 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
