Question about Bosch Classixx WFL 2066 Front Load Washer
When we wash some items it seems to be making small holes in the clothes - is there anything we can do?
    Sergeant:
  • 192 Answers
It sounds like there is a gap somewhere in the basket. If it is still under warranty contact the manufacturer and they should fix due to mechanical failure.
Posted on Mar 21, 2011
I have a Bush F841QW Washing Machine since 18.04.2016,in the last couple months small holes have appeared in clothes following washing.This is very unsatisfactory,can you help please? Wendy Haydon
Have you examined the drum inside? Can there be a needle, nail or any other sharp item sticking in the holes of the drum, which puncture your clothes?
Take a close look and let me know.
Jul 29, 2017 | Washing Machines
We are getting small holes in our clothes? Is
check to see if theres anything in the tub that feels sharp. Make sure theres nothing stuck in the small holes. Also, check out the rubber boot. DOes it look worn? what clothes are getting holes? is it all of them? Colors only? Whites only? Do a maual check on the inside of it with a flashlight to make sure no sharp objest are stuck aor what not?
Aug 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Making tiny holes in clothes
Check drum and agitator for cracks or something that may be hooking the clothes.
May 09, 2009 | Washing Machines
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
Washer making holes in clothes
Feel the drum inside for any sharp object example a pin that is sticking sideways in a hole or the the drum spot-weld spots that came lose making a high spot.
I did find the same kind of a problem with a Defy front Loader machine. You can also check the gap between the door and the drum lip.
Hope this will solve your problem and save yourself from spending big bucks on new clothes.
Clive
Apr 17, 2009 | LG WM-2277HW Front Load Washer
After a washing cycle on wool wash, some items are not completely wet - machine is not overfilled. there is also fluff on some of the items
Look in the area where you place the clothes. in the back area about the 2o'clock posistion there is a small hole. usually this hole which recirculates the water becomes clogged with lint. If there is n othing there, you could have a pump failure,and it is not letting the water get back onto the clothes.
Feb 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Makes scratching noise
Nov 19, 2008 | Maytag PAV2300 Top Load Washer
My Whirlpool Duet is eating small articles of clothing!
Okay...first of all, the "F02" error code is a Long Drain error. This is usually caused by debris clogging the drain pump. There is a drain reservoir that needs to be cleaned out periodically. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Keep in mind, it does not take much to damage these small drain pumps. If anything has been left in the pump for a significant period of time, it can damage the pump motor or impeller. The result: a drain pump that "appears" to be running, but may not be pumping anything. If the error code returns, you may have to replace the drain pump.
The socks getting lodged in the rubber door boot can be a common problem. Well...I should say, its not uncommon for this to happen. Due to the design of the rubber folds in the door boot, it can often collect small items. Sixteen socks is not a new record. I found over 20 one time! This rubber door boot must be inspected after EACH wash load to ensure items do not get stuck there. This can result in articles of clothing beginning to mildew and smell over a period of time as well. There are also small drain holes in the folds that help drain away some of the residual water. If these holes become clogged, water will stand in this area and begin to smell. The following link explains the recommended steps to keep this area clean:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
In addition, it is not unheard of to have small articles of clothing (such as socks, underwear and wash cloths) to manage to work their way between the inner spin basket (stainless steel tub) and the outer tub shell and get lodged in the drain hose. I would recommend you inspect the drain hose that runs from the bottom of the wash tub to the inlet side of the drain pump for obstructions as well. I have found wash cloths stuck in this hose that prevented the tub from draining. For future reference, use garment bags for washing small items. This will prevent some of the problems from reoccuring.
I hope you find this information helpful. Let me know if you require additional assistance.
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
242 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
